CJ5 Wiring Diagram - Off-Road Forums & Discussion Groups
Old 04-05-2006, 04:19 PM
jeepsteve is an unknown quantity at this point
Default CJ5 Wiring Diagram
Probably the first to respond will be Larry or Jim, however, does anybody have a mid 70s CJ5 diagram that you could e-mail me. The links that I had from before no longer work and searching came up with nada. Buddy just got his first Jeep, a 75 CJ5 but the ignition is torn up. Any help to direct him for replacing with a push button start would help.
as always thanks...
Old 04-05-2006, 05:26 PM
OlllllllOCJ's Avatar
OlllllllOCJ is an unknown quantity at this point
Default Re: CJ5 Wiring Diagram
Try here:
<u>Wiring Diagrams</u>
[img]/ubbthreads/images/graemlins/40BEER.gif[/img]
Dale
Old 04-05-2006, 05:33 PM
Ask and you shall recieve. I googled the snot out of wiring diagrams and never got that one to hit. Thanks
Old 04-05-2006, 05:57 PM
It's a good thing Dale found that for you. I have the '78 diagram and, as I suspected, it's nothing like the '75. Probably eight times as much stuff on it. It's hard to imagine how things could have gotten so complicated so quickly.
  #5
Old 04-05-2006, 08:27 PM
John_Strenk's Avatar
John_Strenk is an unknown quantity at this point
Here is the original schematic I merged into one picture to keep from hunting down the wires over the spine.
http://www.luanjp.com/mods/electrica...5-75Merged.jpg
Do you want directions for just the push button for the starter or a switch to turn the ignition Off and ON also.
If you just want the push button look for a light blue wire comming off the back of the old ignition switch. Connect one side of the push button to this wire and connect the other side of the push button to a switched hot point.
  #6
Old 04-05-2006, 09:12 PM
[ QUOTE ]
I'm not taking any credit... Pretty sure that Larry posted the link first (may not have been here).
As for the complicated fast... In 1972 I sold gas at less than $0.60/gallon and it had lead in it. By 1976 I owned an "Unleaded Only" Oldsmobile and the price per gallon had gone up by nearly half.
Was good to get the lead out. Engines last much longer too.
Who the heck said "Necessity is the mother of invention"?
Ahhh then came fuel injection and some really complicated crap.
Dale
  #7
Old 04-06-2006, 11:01 AM
I'm not completely sure what he needs. The Jeep had been 'almost' stolen before he got it and they busted up the ignition switch trying to take it. It may be already wired but its so rigged, he can't hardly tell without the diagram. PO made a lot of electrical "modifications" if you know what I mean. Ultimately he may have to go with a Painless but he needs to start it for now.
  #8
Old 04-06-2006, 11:58 AM
The diagram is quite plain... so let me make a suggestion that may help, and it's cheap to do.
Get yourself a piece of plywood (4'X8'works great). Then cover it with butcher paper that you can write on.
Now completely remove the wiring harness.
Attach the fuse box onto the plywood and start separating the wires into circuits that can be stretched out on the plywood.
You then start affixing the wiring to the plywood and labeling on the paper what the circuit is for.
It's an easy way to see how the wiring lays out, and to where....
It's like following a road map. In fact, if you look at a painless wiring diagram you'll see this type of process used.
When you've got the harness termination points identified you can then tie up the harness into a loom, and cover with plastic sheathing to make it dressed.
Also, Moses Ludel's The Jeep CJ Rebuilders Manual, 1972 - 1986 has a good diagram of the CJ5 (1972) wiring harness. It would go a long way in helping you to understand the layout, what goes where, what plugs into what...
Trust me... it's not as complicated as it seems.
  #9
Old 04-06-2006, 12:23 PM
We still do this were I work
Here is a small harness we make:
Plywood to mount the drawing, use nails in the bends, Springs to hold loose ends until the terminas are atached.
But we use an old technique of lacing the wire together to save room. You can also use wire ties or plastic covering.
  #10
Old 04-06-2006, 12:27 PM
Good Pic John.
Loom making can be a mystery to some.
Can you better describe the lacing technique so it's easier for the great unwashed to understand how to bundle the wiring?
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
