Propane/Gas Jeep? - Off-Road Forums & Discussion Groups
Old 08-02-2005, 11:53 PM
rubiconvict's Avatar
rubiconvict is an unknown quantity at this point
Default Propane/Gas Jeep?
I saw this J-20 on Ebay that can run on either Propane or Gas. Anybody ever done this, Ive never heard of it just curious how well it worked and what all is involved [img]/ubbthreads/images/graemlins/confused.gif[/img]
Old 08-03-2005, 03:15 PM
jlove86CJ is an unknown quantity at this point
Default Re: Propane/Gas Jeep?
This is a really common conversion amoung the farming community. I've never had any real experience with it but my father modified a couple of cars in the 80's that could run off propane and gas at the same time. Just a matter of running plumbing to the carb and setting the mixture right. Propane burns hotter and cleaner than gas, if I remember right there was a question as to wether or not it would damage the pistons over time, but I think that was over quite a few miles (tens of thousands).
Old 08-03-2005, 03:20 PM
Interesting.....its a wonder you dont hear more of this with gas prices going through the roof
Old 08-03-2005, 03:27 PM
JeepDude's Avatar
Journeyman
JeepDude is an unknown quantity at this point
So what is the going price on a gallon of propane vs a gallon a regular pump gas?
  #5
Old 08-03-2005, 03:35 PM
A lot of the deisel guys are starting to do this, more power and better fuel economy.
Of course with any mod for fuel economy purposes you have to weigh the initial cost of the mod vs the amount of $$ saved in fuel. I know I can buy gas @ $2.49 and propane @ $1.50. That saving could add up quick, but most places are now adding road taxes if the propane is being used for powering up a motor vehicle vice being used to heat a home or in an RV or something like that.
  #6
Old 08-03-2005, 03:39 PM
JeepDude's Avatar
Journeyman
Found the price chart on propane...
Charts
Looks like propane's about 43% cheaper. Basically, it's like for every dollar you spend on propane, you're saving 76 cents over gas. That's of course assuming gas mileage stays the same.
So would the mileage stay the same???
  #7
Old 08-03-2005, 03:46 PM
I knew you were able to use propane in a vehicle but just never heard of being able to switch from gas to propane, Ive heard of disels using both but not a gas engine
Here locally (hosier gas) sells propane for 1.25/gallon and gasoline here in indy is about 2.30/gallon
  #8
Old 08-03-2005, 04:14 PM
JeepDude's Avatar
Journeyman
Some good info here.
"Costs
See the current model year light-duty vehicle and heavy-duty vehicle lists for costs of new propane vehicles offered by the auto manufacturers.
Factory-installed light-duty truck conversion costs about $2,500 over the conventional vehicle base price; non-factory conversions also average about $2,500.
Performance
Propane vehicle power, acceleration, and cruising speed are similar to those of gasoline-powered vehicles.
The range for bi-fuel vehicles is comparable to that of gasoline vehicles, but the range of dedicated propane vehicles is generally less than gasoline vehicles because of the lower energy content of propane. (Propane contains about 84,000 Btu/gallon and regular gasoline averages 114,000 Btu/gallon.) Extra storage tanks can increase range, but the additional weight may displace some payload capacity. "
  #9
Old 08-03-2005, 05:00 PM
Carpal \'Tunnel
TiminMb is an unknown quantity at this point
You generally lose some power on a gas to propane conversion unless the compression ratio is increased to take advantage of the higher antiknock properties of propane. Those conversions were very common here in Manitoba in the 80's among fleet vehicles and many taxi cabs still run propane. They used to convert new trucks where I used to work, and they seemed to have less power after the conversion.
  #10
Old 08-03-2005, 06:50 PM
Aprentice
pulento is an unknown quantity at this point
[ QUOTE ]
From what I understand you get fewer miles/gal on propane than on gas.
just my 2 cents.
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
