Re: 3 point seatbelt lower mounting locations? I think, unless someone has been following some "other" thread of yours, you need to clarify what your problem is. Without knowing anything but the information provided in this post, the take-up reel for the seatbelt should be mounted on the floor on the outboard side. The other end is mounted on the floor in the center of the jeep, both are at the centerline of the seatback or behind it. The idea is to strap down the occupant. If the seatbelts are mounted to far forward, the package (you) will have too much lateral movement.
I guess I really don't understand what your concern for schafing is? |
