| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Jeep-Short Wheelbase All discussion of short wheelbase Jeeps: CJ, TJ, YJ |
05-11-2004, 01:53 PM
|  | Carpal \'Tunnel | | | Join Date: May 2001 Location: Canada, B.C.
| | Lemmie get this straight...
I wire #1 to the battery positive (+) terminal.
I wire #2 to #1.
and..
I wire #3 to the ground side of a 12V switched idiot light.
Sounds like a plan? |
05-11-2004, 03:59 PM
|  | Veteran | | | Join Date: Sep 1999 Location: The Plywood State.... Florida
| | Re: Lemmie get this straight... That will work. But the voltage will be referenced to the back of the alternator (number 1) rather than a point farther down the wiring harness. You may want to look at this post. Alternator wiring |
05-11-2004, 04:17 PM
| | Re: Lemmie get this straight... TeamRush saves the day again. [img]images/graemlins/grin.gif[/img]
and he hasn't even been here in a long time.
For reference.
So if I ran a voltmeter, I can dump the idiot light?
Or better yet dump the volt meter and run an idiot light?
And the #1 wire should run to something on the other side of the fuseblock that is switched (ign) 12V ? no? |
05-12-2004, 07:24 AM
|  | Super Moderator | | | Join Date: Dec 2001 Location: Belleville, Illinois
| | Re: Lemmie get this straight... </font><blockquote><font class="small">In reply to:</font><hr />
No. The idiot light in the drawing also serves the purpose of providing the resistance necessary to kill the ignition system when the switch is shut off. Without it current will flow backwards from the alternator to the switch, and from there to the ignition system, and the engine won't shut down.
The idiot light can be replaced with a resistor, a piece of resistance wire (the factory's solution on Jeeps without a light) or a diode.
And regarding where the 'B' connection is made, if you have a vehicle that uses a lot of electricity a significant part of the time, it's important that you connect as close to the battery as possible. That's because if there is a high current flow out of the alternator, there will be a drop in voltage between it and the battery. That will result in the battery not reaching its full charge.
If your vehicle doesn't normally use much electricity it's fine to connect 'B' directly to 'Batt'. I tested that on my Jeep and found no difference in voltage at the battery whether 'B' was connected directly to the battery or to the 'Batt' terminal of the alternator. But at the time the only electricity it was using was to power the ignition system. If you have lots of lights, a winch, or some other high-current device, where 'B' is connected can make a difference. | | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! | All times are GMT -5. The time now is 12:36 AM. |
