Matching Axles ratios front to rear - Off-Road Forums & Discussion Groups
Old 04-23-2004, 01:17 PM
GoldToyBox's Avatar
Location: Selma,CA in the middle of the vineyards, Central California
GoldToyBox is an unknown quantity at this point
Default Matching Axles ratios front to rear
Do axle ratio's have to match exactly (front to rear). Found this in an add:
Ring and pinion sets. Dana 30 front with 4.10 ratio / Dana 44 rear with 4.09 ratio.
Maybe a typo? Just got me to wondering How close the ratios have to be if not exactly the same? I thought some full time 4x4 rigs had differnt ratios to allow for some slippage before the front axle would see any torque? Or is that some "garage talk bull#&amp;$t.
[img]images/graemlins/RockOn.gif[/img]
Old 04-23-2004, 01:44 PM
Randyzzz's Avatar
Randyzzz is an unknown quantity at this point
Default Re: Matching Axles ratios front to rear
4.09 to 4.10 is just fine. Fords and other models have been running that way for years...
Old 04-23-2004, 02:51 PM
It's also the same reason they tell you not to run in 4low on pavement...dirt has give and will not bind up the xfer case.
Old 04-24-2004, 12:39 AM
WILL's Avatar
Official Historian
WILL is an unknown quantity at this point
The difference in ratio has nothing to do with trying to get one axle to spin faster than the other. This is a reply I wrote on 8/13/00 and again on 4/29/02:
the front and rear axles usually have different diameter ring gears. sometimes this difference is why they have a different number of teeth. for example: a dana 44 4.09:1 ratio has 45 teeth on the ring gear and 11 teeth on the pinion. (ring gear diameter is 8 3/4"?) 45/11=4.090909... a dana 30 4.10:1 ratio has 41 teeth on the ring gear and 10 teeth on the pinion. (ring gear diameter is 7.5"?) 41/10=4.10. this little difference in ratios isn't enough to worry about.
This is from 12/02/02:
The reason the front and rear are different on many 4x4's isn't because one end is designed to "outrun" the other. The reason is very simple: they are usually different model axles. With different models, such as a dana 30 front and 35 rear, the ring gears are different diameters. That means that the teeth count probably won't be the same which is where the slightly different ratio NUMBER comes from. From a design view, 4.09, 4.10, and 4.11 for example, are the SAME. They are that close. Again, the difference is just due to the different diameter ring gears and pinion gears. That's all, nothing else.
The number of teeth on the ring gear is dependant on the diameter of the ring gear. Different diameters mean different tooth counts for the "same" ratio.
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
