Front driveshaft play? - Off-Road Forums & Discussion Groups
Old 08-29-2003, 01:51 AM
Default Front driveshaft play?
How much Play should the front driveshaft have?
My rear has almost none.
But the front seems really sloppy.
Is that acceptable, or maybe this is the reason
I'm getting FUNNY NOISES when I cruise in neutral.
Old 08-29-2003, 03:35 AM
speed_buggy's Avatar
speed_buggy is an unknown quantity at this point
Default Re: Front driveshaft play?
I get a funny chain wip nosie when I let off the gas in 4wd. I used to worry, but then I rode in my buddies 2003 dodge cummins 4x4 dually, it made then same noise when he drove half up a curb and let in the clutch( we rolled back.)
and you need to do something about that too long rear drive shaft.
FYI about the D35, you might look into ford 8.8s in the local junk yards. I did some searches on car-part.com and there are explorer 8.8s with 4.10s in the aera for ~$750. its a reasonable deal if you stick with the gears and the LS that it comes with.
Old 08-29-2003, 05:43 AM
jdoggmoney's Avatar
jdoggmoney is an unknown quantity at this point
I think he means wobble play. Dont you? [img]images/graemlins/grin.gif[/img] Making sure the slip joint is full of grease can take some of the "slop" out, but odds are you need a new slip joint. Look for a good used front shaft that's the same length or take it to a reputable driveshaft shop.
I suppose this could be the source of your noise. Easy to check... take it off and go for a ride. Good Luck! [img]images/graemlins/grin.gif[/img]
Old 08-29-2003, 09:36 AM
Pigpen is an unknown quantity at this point
Is the play at the slip joint where the lower and upper shaft meet? If so then try the grease, if that doesn't work pull it and repair/replace. If the play is at either end then the spider (u-joint) needs grease or is bad. Or the bearings in the t-case or axle could be bad or loose. Start by greasing everyything and then pull and push in the different areas for play. There should be close to none.
  #5
Old 08-29-2003, 12:41 PM
The play is actually rotational.
I can actually twist the driveshaft a good
ways before it catches on a gear.
Since I'm under the YJ today I'll take off the driveshaft
and see if the play is coming from the Tcase or the front
axle.
And grease is up too.
Hey SB.
I found some D44s, but they're still attached to
the jeep. [img]images/graemlins/laugh.gif[/img] The 8.8 intrigues me though. Rear disk
brakes are always nice. I'm sure If I hit some junkyards
I'll find some explorers.
  #6
Old 08-29-2003, 01:12 PM
I can to. It's been fine for many miles. I don't know if this is bad, but I haven't had any troubles. No weird noise, but I have a TJ the front shaft turns all the time.
  #7
Old 08-29-2003, 02:56 PM
WILL's Avatar
Official Historian
WILL is an unknown quantity at this point
If you have the transfer case in 2wd and the front axle has disengaged, you should be able to turn the driveshaft freely round and round. If you have a locker in the front, there's nothing wrong.
  #8
Old 08-31-2003, 02:19 AM
nesalc
I got the same on both my front and rear axle. With the driveshafts disengaged I can turn the input like 3" before the wheels starts turning.
I have been wondering if this is a problem, or supposed to be like this.
/Claus
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
