how loose should push rods be? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-30-2003, 10:13 PM Thread Starter
the jeep just started making a terrible engine noise (or it just got bad enough to hear with the top off) sounds like the valves, so i check the timing around 8* so that is ok. took the valve cover off and all the bolts are tight, but the rockers and push rods are loose and have some play in them. they weren't all loose b/c i assume those were the ones that were compressing a valve, but more than half were loose. they shouldn't ever get so loose that they have play in them should they? i had a problem with one lifter last fall, the 'ball' that sits on the end slipped down inside and made it loose, but i replaced it and haven't had trouble since. but now it seems that they are all loose. i took one out and looked at it and it looked fine. any ideas here? it is getting really bad. also it has about 15k on it since it was completely rebuilt.
thanks all
shawn
80cj is offline
post #2 of (permalink) Old 07-01-2003, 07:18 AM
M38
Re: how loose should push rods be?
really in some book somewhere there should be a measurment you can make with a feeler gauge
more than likely on the TDC on each cylinder just slide it under and check
not sure about your motor but with Small block chevy's you used to able to tighten slowly until the rattle stopped and back off a little and they were fine, (hydrualic lifters)
clint
M38 is offline
post #3 of (permalink) Old 07-01-2003, 07:53 AM
If they are hydralic lifters there is not any gapping. The rods should be lose enough to spin when not under pressure but you should not be able to pull/push them up and down. When the cam lob comes up the spring in the lifter is compressed and allows the oil pressure to send oil up the tube. Bad lifters will sometimes get stuck in the compressed compression and the tap that can be heard is the cam wacking the lifter, or lifter wacking the rod/rocker due to the gap between the two. You can try to add automatic tranny fluid to your engine oil. Run the engine for about 1 hour and change the oil with reg oil. The tranny fluid is less thick and can clean sticky lifters.
Pigpen is offline
post #4 of (permalink) Old 07-01-2003, 07:53 AM
Anything is possible but if you had a complete rebuild and the problem was not there in the beginning it sound like a bad lifter.
Pigpen is offline
post #5 of (permalink) Old 07-01-2003, 09:05 AM
[/ QUOTE ]1. Pigpen's right!
2. Give that the lifter is pumped correctly,
3. When not under pressure you should be able to "spin" the push rod.
4. Push rods and lifter faces are designed to create that spin.
5. This helps keep down wear.
6. As the lifters and the rods spin,
7. Different contact points are made.
8. This is one of the reasons[*] You ALWAYS put the push rods back in hole they came out of[*] You never Polish 'em[*] You replace lifters... you should replace the push rods as a set.
9. Examine the rockers for a bad wear pattern where it contacts the push rod.
10. If the rocker arm is cupped the push rod may not be spinning,
11. That indicates wear.
post #6 of (permalink) Old 07-01-2003, 09:16 AM
Pooh-Bah
uglyjeepoffroad's Avatar
If it has been making noise the whole time, there may be a problem with the push rods.
I have recently been researching the lengths used by AMC and there are at least 3 distinct length push rods.
9.56" for early 258's with seperate rockers
9.65" for early 258's with a rocker bridge
9.70" for later 258's with seperate rockers
Mine were too short on my rebuilt engine and I was getting valvetrain noise. Sounded like a deisel, just without all of that annoying power. [img]images/graemlins/bs.gif[/img]
I ordered a set of the 9.70" ones to take up the slop. I haven't installed them yet, but they measure out right and should do the trick. [img]images/graemlins/RockOn.gif[/img]
uglyjeepoffroad is offline
post #7 of (permalink) Old 07-01-2003, 12:43 PM Thread Starter
there is up and down play in almost all of them. i can tap the rockers and they have play in them. it is just really odd to me that they all seem to be going at once. changing them is not a big deal, but i am worried that it may be an indication of a bigger problem. but what can it be?
thanks all
shawn
80cj is offline
post #8 of (permalink) Old 07-02-2003, 07:57 AM Thread Starter
so can anyone think of anything else that would cause this? if not i guess i will just try to replace all the rods. the rods i have now are hollow tubes with balls welded on the end. are these a cheap version?
thanks all
shawn
80cj is offline
post #9 of (permalink) Old 07-02-2003, 08:36 AM
Caver Dave's Avatar
[img]images/graemlins/laugh.gif[/img] [img]images/graemlins/laugh.gif[/img] [img]images/graemlins/laugh.gif[/img] [img]images/graemlins/laugh.gif[/img] [img]images/graemlins/laugh.gif[/img] [img]images/graemlins/laugh.gif[/img]
I was wondering when you were gonna chime in!
And what's the issue in the D30? Any chance of getting it "all" back together in time for URE next weekend (July 12)?
Caver Dave is offline
post #10 of (permalink) Old 07-02-2003, 08:42 AM
Pooh-Bah
No. Radiator prices are killing me.
I haven't torn into the 30. I was waiting to get the radiator replaced before I get into it. If I get the radiator replaced, I can at least drive it.
Human Verification
