Home made Posi-Lock for a YJ - Off-Road Forums & Discussion Groups
Old 05-16-2003, 08:13 PM
CJJ92YJ's Avatar
CJJ92YJ is an unknown quantity at this point
Default Home made Posi-Lock for a YJ
Has anyone out there ever made a homemade "Posi-Lock" for their YJ? My actuator has gone out and I am tired of replacing it. I might just be a tightwad, but $200 for the Posi-Lock seems a little high for a few clips and a pull cable. I'm sure it's not actually that simple, but I was just wondering if anyone has ever attempted such a thing, and what all it took to make it work. Maybe if it's an easy enough thing to do, and someone had a good "How-To", then more people would do it. Hell, if I could do it for less than $40-$50, I would make the swap even if my actuator still worked! Anyone else out there think like me, or am I all alone?? [img]images/graemlins/confused.gif[/img]
Old 05-16-2003, 08:42 PM
Skellator's Avatar
Skellator is an unknown quantity at this point
Default Re: Home made Posi-Lock for a YJ
This is the only write up I've found. I spent a couple hours last night looking for a new one without any luck. [img]images/graemlins/crybaby.gif[/img]
I've been told that it's a little tough to follow. [img]images/graemlins/frown.gif[/img]
It's on my list of to do's.
How To: Dana 30 Shift Motor Vacuum to Cable Conversion
HTH [img]images/graemlins/RockOn.gif[/img]
Old 05-16-2003, 09:30 PM
Sycho15's Avatar
Sycho15 is an unknown quantity at this point
If your vacuum actuator is useable (or if you go to the junkyard and get a good one) you can rig a 3-port vacuum switch and take manual control of the disconect by running new vacuum hoses to that switch. I'm doing this to my Comanche with a switch from an '86 XJ with "select-trac". Back then they used the vacuum-selected NP-229(?) x-case. Installed in my truck it should look factory to the untrained eye. Lots of '80-84 Grand Wagoneers used 3-port switches as well, mounted under the dash to the right of the steering column.
Old 05-16-2003, 09:50 PM
Skellator's Avatar
I found a write up for that too. [img]images/graemlins/grin.gif[/img]
2 low conversion
  #5
Old 05-17-2003, 09:59 AM
CJJ92YJ's Avatar
Thanks for all the help. I thought it would be pretty simple, but the more I read that article, the more I am confused. Anyone out there got a simpler explanation?? [img]images/graemlins/confused.gif[/img] [img]images/graemlins/confused.gif[/img]
  #6
Old 05-19-2003, 06:16 PM
jeepnmatt is an unknown quantity at this point
its not that difficult once you get it apart and see what it needs to do.
this is the cable you will need: www.mcmaster.com do a search for pn 6161K12. its $30
now look at the BC4x4 write-up again and it should back sense.
matt
  #7
Old 05-19-2003, 06:30 PM
CJJ92YJ's Avatar
thanks for the link. You are right. And the more I look at it, the more it makes sense to me. I think I am definitely gonna try it, after all, I will only be out $30 if I can't get it to work. But it looks rather simple now that I've steined over it for a while. Thanks everyone. [img]images/graemlins/goodpost.gif[/img]
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
