bent leaf spring - Off-Road Forums & Discussion Groups
Old 04-01-2003, 12:04 AM
ODgreen
Default bent leaf spring
I have 4" superlift springs on my cj7 And i just recently bent the passenger side rear spring up by the military wrap i think i only bent the main spring. I bent it on the stationary frame mount. now my tires are out of alignment big time. How do i fix? can i? I live in a remote town 6 hours away from anchorage and i dont make it there very often can i fix it myself? Maybe put in a hydralic press or beat on it. Is anyone familiar with superlifts warantys can they sell me just a main spring? any info on bent leaf springs would be greatly apreciated.
Old 04-01-2003, 12:43 AM
4x401CJ5 is an unknown quantity at this point
Default Re: bent leaf spring
I would call Superlift and see if they`ll sell you the main spring. They`ll probably want to sell you a whole new
spring. Your not going to be able to fix it yourself. You might try to find a spring shop localy. They could
possibly help you. I know, you said you were remote, its just a thought.
Old 04-01-2003, 07:50 AM
Olin18 is an unknown quantity at this point
I think if I were you I would get a whole new spring. Even if the main spring is the only one that looks bad, it may not be. And if you replace it, and the other springs are not holding their own, then you may be faced with the same problem down the road. If you lived somewhere that you could just get a spring around the corrner, then I would say go cheep. But it is probably worth it to not have to make the 6 hour drive twice. Maybe if you call the company they will agree to give you a deal on a new spring... They should not bend like you reported.
Old 04-01-2003, 01:49 PM
Pooh-Bah
cj5_pilot is an unknown quantity at this point
OD, sorry I don't know of a closer spring outfit than Anchorage. However, you might just give Alaska Spring there a shout. They are good people and should be able to at least give you some good advice. (They did my spring re-arch/add-a leaf and replaced one of my main leafs and I've dealt with them for over 10 years...my father's been dealing with them since '83)
Talking to Superlift first would be the best bet. I don't think there is much you can do at a home shop to fix a bent spring. I'm pretty sure it's a take it to the shop or replace it kind of thing.
Oh, you might call Northern 4x4 and see if anyone has a spare superlift 4" spring pack laying around for a CJ7. They do a lot of biz and might be willing to ship it to valdez for you.
Good luck with it!
  #5
Old 04-02-2003, 08:25 AM
Just a few days ago I straightened a leaf spring. It is a stock '78 CJ7 front with factory HD suspension. It has a secondary main leaf that is below the main leaf and wraps loosely around the eyes. Those two leaves were bent about a third of the way from the axel to the rear eye. The bend had those leaves raised about an inch above the rest of the spring pack, which was not damaged.
I just put it in the press, supported about three inches either side of the bend, and pumped down on it. The third try, going a little farther each time, had the bend almost completely removed. I decided to stop there rather than go farther and risk putting a backwards bend in the rest of the spring pack.
Had the bend not come out I would have disassembled the pack, but fortunately that was not necessary. No problem.
  #6
Old 04-02-2003, 08:32 AM
Although it is true that you can bend a spring back. Metal has a tendency to bend again after damage has been done. There will be a weak spot in the spring pack. And although fixing it is great, and perhaps it will never bend again. If it were me, and I lived a 6 hours from the shop.. 12 hour round trip. I think I would just go with a new spring, and save yourself the chance of future headacks. But that is Just my opinion
  #7
Old 04-02-2003, 09:05 AM
In this case, replacement is probably the best choice, especially since it sounds like the damage is right around the eye. Not only will it be more difficult to straighten, but it will recieve more stress to boot.
  #8
Old 04-05-2003, 12:12 AM
ODgreen
Good news my dad had to make a emergency trip to anchorage this week so i quick ran and put the jeep on blocks and dissasembled the spring pack. I gave him the spring and adress to Alaska spring which i previously called and made arangments with (very nice people by the way, very helpful)
The fixed it for $14.50 and it took them about 45 minutes. sweet huh!
Thanks cj5pilot for the tip on alaska spring
  #9
Old 04-05-2003, 02:35 AM
knifeboy2's Avatar
Carpal \'Tunnel
knifeboy2 is an unknown quantity at this point
I have to kinda laugh at that. I thought Macomb, IL was in the middle of nowhere but you have proven me wrong. Its always good when you get things fixed.
  #10
Old 04-05-2003, 02:47 AM
Pooh-Bah
Great! I'm glad they were able to help. Yep, they sure are great people. BTW, if you get up towards they valley this summer, let me know. Maybe we can go wheeling....or maybe I can run down your way sometime!
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
