Fusible links - Off-Road Forums & Discussion Groups
Old 02-10-2003, 12:52 PM
Carpal \'Tunnel
TiminMb is an unknown quantity at this point
Default Fusible links
Why do the OEM's use fusible links and not replaceable fuses in the main power lines and alternator to battery line? Why is there a fusible link between the alternator and the starter solenoid? If half the wire burns up as a fusable link, why not just use 8 awg for the whole 12" wire? It would be the fusable link since it's connecting to the 4 awg or larger starter cable?
Old 02-10-2003, 06:35 PM
Carpal \'Tunnel
Default Re: Fusible links
Went to the auto parts store looking for wire. Nobody in this town has 8 gauge wire for the alternator. Found a 175 amp alternator fuse ($5.00) that would bolt onto the lug of the alternator or solenoid. I am considering that option along with some 4 gauge for the cabling. Don't need that gauge, but there doesn't seem to be anything in between around here, although I am sure I have not as yet exhausted all local sources.
Old 02-10-2003, 06:48 PM
1. The wire's under constant current draw.
2. A fuse has a cycle life, so many hits and it blows...
3. Even a so called "slow-blow" fuse.
4. Fusible links are more robust,
5. They just plain last longer...
6. But can be a PITA to repair,
7. Because there's not visual indication when they go bad.
Old 02-10-2003, 08:07 PM
And they use a short piece of fusible link instead of running it the whole length so that if it burns up it limits the damage to a small section of the harness instead of destroying the whole thing.
  #5
Old 02-10-2003, 08:15 PM
The_Bishop's Avatar
The_Bishop is an unknown quantity at this point
"7. Because there's not visual indication when they go bad."
Hah! You should have seen my fusible links after my now disco'd electric choke wire grounded out! Well, I *thought* it was taped well!
  #6
Old 02-10-2003, 08:51 PM
1. Bishiop, "go bad" is a lot different than,
2. Being Murdered by a direct short!
3. Then they scream their little heads off...
4. It's similar to waking up dead someday...
5. Or being Father Isaac Jogues.
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
