ADVERTISEMENT
  #11
Old 01-22-2003, 01:31 AM
oldp is an unknown quantity at this point
Default Re: anybody tried a 2002 4.0 swap
Which thread on the pirate are you referring to ?
Can you post a link ?
Seems like the more info I gather on that swap the easier it should be !
  #12
Old 01-22-2003, 09:01 AM
sirhumpy
4.0 Swap/Spark Problems thread
  #13
Old 01-22-2003, 09:35 AM
Thanks for the link ! Tons of info on a 4.0 L OBDII swap...
Looks Doable !
  #14
Old 01-22-2003, 11:36 AM
RickB's Avatar
RickB is an unknown quantity at this point
oldp - this is what a fuel rail looks like from a '93. The part on the end of the tube is the built in regulator.
  #15
Old 01-22-2003, 02:27 PM
Thanks for the pic Rick ! At least now I know what the fuel rail is.
Is A the fuel line and B the return line ?
  #16
Old 01-22-2003, 03:46 PM
85Jeepny
B is the supply fuel line, A is the return...
  #17
Old 01-22-2003, 04:14 PM
Thanks 85jeepny...I can't wait to get started on my swap...
  #18
Old 01-22-2003, 09:37 PM
dorfs is an unknown quantity at this point
You may run into more problems that just wiring. The entire front drive is different. On the older 4.0l's, up to about 2000 had a common front serpentine drive and motor mount style. The old '80's 258 would swap over almost direct, including the motor mounts. On the newer DIS 4.0's, the entire bolt pattern for all accessories and motor mounts are different. Take a close look at the block and see if the motor mounts will swap over. You may have to fab something up. You can always use the entire front of the new DIS 4.0 on your CJ, but fabbing the mounts may be a challenge.
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
