different gears in front and rear - Off-Road Forums & Discussion Groups
Old 06-22-2002, 09:53 PM
Default different gears in front and rear
Can I run 373 gears in my front and 456 gears in my rear axle? Is this going to caus eproblems?
Old 06-22-2002, 10:17 PM
Default Re: different gears in front and rear
Yes it will cause problems in 4wd.
Old 06-22-2002, 10:37 PM
Some mud racers over here run different ratios and dont have any problems, but one of my friends tried it is his k5 and destroyed his xfur case.
Old 06-22-2002, 11:03 PM
WILL's Avatar
Official Historian
WILL is an unknown quantity at this point
The mud racers also run different diameter tires so that one revolution of each driveshaft equates to the same distance covered by the tires.
If you run different gear ratios due to money reasons, at least remove the front driveshaft. That way you'll never either accidentally engage 4wd or get into a situation where you'd be tempted to use it to get out of a stuck.
  #5
Old 06-23-2002, 12:26 AM
OregonSahara's Avatar
OregonSahara is an unknown quantity at this point
Right now, I am running 3.07's in the front and 4.09's in the rear. But as Will points out, I can't use my 4wd without breaking something. I am doing the regearing myself and since I am a rookie, I wanted to make sure I have set the rear up correctly, before jumping to the fronts.
-OS
  #6
Old 06-23-2002, 10:38 PM
Brhino is an unknown quantity at this point
wow-people actually do that huh? Not here in Iowa but we are boring. Yes it will cause you problems in 4wd-if you only run 2wd, why buy a Jeep? Cars are cheaper. My prediction-you will tear up the 3.73s. Smaller gears and the front won't be able to pull the rear for very long. Replace both.
  #7
Old 06-23-2002, 11:05 PM
WILL's Avatar
Official Historian
My bet is the transfer case.
Please post which breaks first.
  #8
Old 06-24-2002, 09:16 AM
Do you have connections in Las Vegas? Maybe someone could posts some odds and we could make his Jeep a game!!
  #9
Old 06-25-2002, 10:03 AM
Swede is an unknown quantity at this point
I bought a t-case from a guy who had a YJ that did not have the front driveshaft hooked up when he bought it. The original owner said 4wd worked fine. When the new owner hooked up the driveshaft and put in 4wd, he promptly sheared off the front output shaft. The previous owner didn't tell him that he had changed the rear gears from 4.10 to 3.07 for "better gas mileage"!
I got this t-case for the input shaft to do a BA-10/AX-15 swap so the output shaft wasn't a problem.
  #10
Old 06-25-2002, 10:40 AM
rock_monkey is an unknown quantity at this point
ive heard of the heavy metal trucks doing that in the races and for baja, but i would think the split is fractional like 4.56 in the front and 4.50 in the rear. of course, if you have the money to run a truck like that, you can afford to have custom ratios cut for you. the explanation i heard for that was that the front will pull the truck more than the rear will push, keeping the truck more controllable in the high speed, loose surface straight aways, keeping the fishtailing to a very minimum.
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
