ADVERTISEMENT
Old 09-29-1999, 10:13 AM
Default ignition switch?? HELP
Hey guys
My 84 cj7 keeps blowing a fuse. The ignition fuse or something. When it blows, it stalls the motor and won't restart. Would this be a ignition switch problem? Any suggestions?
Brian "A4x4jeeper"
http://members.aol.com/a4x4jeeper/
http://www.jerseywheelers.org/
Old 09-29-1999, 10:55 AM
The_Sandman_454's Avatar
The_Sandman_454 is an unknown quantity at this point
Default Re: ignition switch?? HELP
What kind of accesories are you using when the fuse blows? It sounds to me like a short in one of the circuits that are working off that fuse. How long does it usually run before the fuse pops? Do you have a chart or similar item showing what fuses in the fuse block go to what system(s)? This will be an invaluable tool in finding out what the problem is. I doubt that it'd be the ignition switch, but if it has a short in it, it could be. More likely, in my opinion, and from the experiences I've had with wiring and fuses, it's a wire that's shorting out somewhere (this will be after the fuseblock, otherwise it'd just burn part of the wire instead of blowing a fuse). Good luck finding/fixing the problem. Hope that helped...
Tim
"The_Sandman_454"
[img]/wwwthreads_images/icons/cool.gif[/img] '79 GMC Suburban 4x4 and '85 GMC S15 4x4
Old 09-29-1999, 10:57 AM
Hey thanks,
I backed the jeep up about 5 ft and the fuse blew again. I don't have anything running on that fuse. I will look at the manuel for what runs off of it. Thanks.
Brian "A4x4jeeper"
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
