Supercharger for Inline 6? How fast? - Off-Road Forums & Discussion Groups
Old 05-17-2002, 02:44 AM
Default Supercharger for Inline 6? How fast?
Just wondering who makes a supercharger for an inline 6? also how fast can ya'll get with the inline 6? Like topped out? Just wondering... thanks
Old 05-17-2002, 03:01 AM
Default Re: Supercharger for Inline 6? How fast?
<a target="_blank" href=http://www.vortechsuperchargers.com/></a>
Old 05-17-2002, 03:20 AM
CJDave is an unknown quantity at this point
[img]images/icons/smile.gif[/img] Now hold on there son. A supercharger is gonna improve the performance; no doubt about it, but before you broke the sound barrier, you'd probably break the crankshaft.[img]images/icons/crazy.gif[/img] Soupy chargers can overcome the low volumetric efficiency caused by intake losses and low atmospheric pressure, and really get your mill up and cranking.[img]images/icons/tongue.gif[/img] When you step on it at 60 it feels like stepping on it at 35.[img]images/icons/smile.gif[/img] THE PROBLEM[img]images/icons/shocked.gif[/img] is the bottom end of the engine, since the compression ratio is set for a naturally-aspirated engine, crankshaft overload and premature detonation can easily occur when boost pressure rises.[img]images/icons/frown.gif[/img] Superchargers are FUN,[img]images/icons/smile.gif[/img] however. We used to install the McCulloch kits on cars in the fifties.[img]images/icons/crazy.gif[/img]
Old 05-17-2002, 09:18 AM
JesseA
I could only assumbe it would be SICK Fast. Remember what a regular 258 or 4.0 will do. if you do do it - please make sure you have a fresh bottom end. there are turbo kits you there for the AM inlines. I suppose those would be a little more serviceable. i have always toyed with the idea of a turbocharged 258 powered AMC Eagle.
Jesse
  #5
Old 05-17-2002, 10:39 PM
Tippy's Avatar
Tippy is an unknown quantity at this point
I think HESCO in Alabama makes a supercharger kit.
  #6
Old 05-17-2002, 11:38 PM
Remember my post from last Sept. about the blown 4.0 TJ? Here's some pics and a link to the thread. The owner Jerry Bruce said you have to be real careful, once the blower kicks in traction is an iffy thing!
<a target="_blank" href=http://tellico.off-road.com/ubbthreads/showflat.php?Cat=&amp;Board=offroadjeepshort&amp;N umber=534004&amp;page=&amp;view=&amp;sb=&amp;o=&am p;fpart=all&amp;vc=1>tellico.off-road.com/ubbthreads/showflat.php?Cat=&amp;Board=offroadjeepshort&amp;N umber=534004&amp;page=&amp;view=&amp;sb=&amp;o=&am p;fpart=all&amp;vc=1</a>
  #7
Old 05-17-2002, 11:45 PM
GeeAea's Avatar
GeeAea is an unknown quantity at this point
try here:<a target="_blank" href=http://www.accuratepower.com/Jeep/Supercharger.html>http://www.accuratepower.com/Jeep/Supercharger.html</a>
  #8
Old 05-18-2002, 01:13 AM
Pooh-Bah
cj5_pilot is an unknown quantity at this point
Also check out Clifford Performance. They are the inline 6 gurus. Their motto is 6=8. I've used their parts in 292 Chevys and 300 Ford I-6s. They've always treated me fairly. I think this is their url:
http://www.cliffordperformance.com
They can also point out the best ways to hop up your six without a supercharger. We put a RV cam, dual headers and a 4 barrel carb on a 292 that we stuffed in a guys FJ40. Sounded nice (sixes with true dual exhaust sound WICKED), and with little 30x9.50 tires, like to have flipped the thing upside down when you stepped on the gas. Anyhoo, check with them.
  #9
Old 05-21-2002, 05:47 AM
Junk Yard Genius's Avatar
Junk Yard Genius is an unknown quantity at this point
*How Fast!?*
Well, how much money do you have?
Speed costs, how fast do you want to go?
<hr>
CJ Dave started to get into it, but I have the scoop on force fed engines...
Super chargers on an I-6 are a pain in the a$$.
Especially if you don't have a flow through head (intake on one side, exhaust on the other)
Then you have to think about things like Draw through or Blow through, Sometimes referred to as 'Wet or Dry'...
Do you want to blow the boost through a carb, or do you want to draw the fuel and air mixture through the supercharger?
Draw through is easier, but has lag problems (slow throttle response), and if you ever have a spark in the supercharger, the entire intake tract is going to gain altitude in a most spectacular way!
(Ever see a top fuel car loose a supercharger?!)
Now you have to think about what type of supercharger you are going to use...
Roots type, Blower Drive Service, Wayand, (positive displacement), Paxton/ McCulloch/ Vortech (Centrifugal), Turbine (Axial Flow),
Then you have to consider the drive method...
Exhaust Turbine (commonly referred to as a Turbo Charger)
Ridged Drive, Wide belt and heavy duty 'snout' like top fuel cars.
'V' belt drive, like Paxton and Vortech.
Mechanical drive like some Roots type use.
Then there is fuel delivery.
Supercharged engines require fuel delivery three times (3X) faster than naturally aspirated engines.
They don't use three times as much fuel, that would be easy...
You have to deliver the fuel three times FASTER, or the engine will melt down.
Just try and think of how you will deliver fuel FASTER if you are running a carb...
(and people b*tch about us taking 30 hours to modify a set of carbs for supercharger use!)
Now you can consider the engine you want to install the super charger on...
If you keep the boost pressure under 7 psig, then you will only have to make sure you have used the best off the shelf, stock replacement parts you can lay hands on during rebuild...
You will not get the performance gains you are wanting with just 7 psig....
<hr>
If you want to go above 7 psig on a 258 CID I-6...
You will need...
a custom made forged steel crankshaft, custom made forged steel or stainless steel rods, new rod bolts, custom made steel block main caps, main cap studs, Forged pistons, high quality rings (gap-less preferable), and high temp valves and valve seats.
You will also have to 'O' ring heads to keep head gaskets in place, you will have to use sealer or fitted intake tract components, ect....
<hr>
A V-6 would be a much better idea if you wanted to supercharge something....
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
