ADVERTISEMENT
Old 09-25-1999, 07:06 AM
Default carb problems
I have a 77 CJ7 with 304 and a 2-barrel motorcraft. It was running way rich so I rebuilt the carb. After the rebuild it was running fine, but now it is starting to run a little rich again. Also after it warms up if I shut it down it will start right up with no problems, but if it sits for a few minutes it is hard starting and acts like it is flooded. What a pain! I am sure somebody out there has had a simular problem. I would like to fix it. If not I would like to put an aftermaket intake and carb set-up. Any suggestions? How about fuel injection?
Old 09-28-1999, 03:40 PM
Default Re: carb problems
I had a similar problem with my 2 barrel weber. I fiddled for a year or so getting stuck often. This past year, i replaced my stock headers with aluminum and i put an edelbrock 4 barrel carb, w/ a fuel flow adjuster. I have not had any problems since. This upgrade is not expensive as far as jeep upgrades go, but it works like a charm..I was looking into a fuel injection system, but decided it was to expensive at this point. good luck.
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
