2 battery set-up?? - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeep-Mid-Sized
Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee
Old 07-10-2001, 12:44 AM
tazman85305's Avatar
tazman85305 is an unknown quantity at this point
Default 2 battery set-up??
Does anyone have a 2 battery set-up? Got pics? I am probably going to upgrade to a 200 amp alt but I want to add a second battery also. Gotta find a good place to put it first.....any ideas?
If it's not dirty, you aren't doing it right.
Old 07-10-2001, 07:45 AM
athlonaj is an unknown quantity at this point
Default Re: 2 battery set-up??
I thought about that myself but gotta get the alternator first. If you have done the K&N air tube mod then you should have enough room where the stock air box used to be. Now I put my coolant overflow bottle there when I did my radiator upgrade so I've got a nice big empty spot where the factory pressure bottle was. I was thinking about making a tray for a battery up there. You could always put a battery in the back somwhere in battery box but then you're looking cable all the way back there. Sometimes that's more trouble than it's worth.
89 XJ/lots of homemade mods...
Old 07-10-2001, 08:26 AM
Enjoyinglife121 is an unknown quantity at this point
Hey tazman,
I've got a duo-Optima (yellow and red) setup routed through a Wrangler battery isolator. I also have a Mean Green 200 amp continuous duty alternator.
I couldn't find an XJ kit anywhere, so I finally had a custom installed performed. It was expensive, but I've been very happy with the results to date. He's how I handled it.
1) Optima yellow deep cycle (secondary battery)
2) 25 feet of 1 gauge high quality fine wire cable.
3) Military connectors.
4) Wrangler battery isolator for battery management with LED switch on console
A) Runs from primary only (charge and usage).
B) Runs from primary but charges secondary.
C) Runs from both.
5) Swapped out the stock air box for Rusty's air tube (makes room for the extra battery).
6) Custom made secondary battery box.
It was a time consuming but fairly straight forward install. The custom wiring was time consuming aspect of the job.
I still need to change the main junction of the battery and electrical system lead which is only a 8 or 10 gauge wire to 4 gauge, beef up my ground and beef up my alternator to relay wire. All my above work, is still being clogged by not finishing the job.
Here is a link to a great article on electrical upgrades that piaa_nissan initially found.
http://www.olypen.com/craigh/charge.htm.
Hope this helps,
Kent
94 XJ (purchased July 00)
Skids, XD9000I, Lights, Bumpers, CB/Ham/Scanner, Due roof racks, ARB compressor, Duo-Optima's, 200 amp alt, and too much more to list!
These trucks rock!
Old 07-11-2001, 12:52 AM
I haven't done the air tube set-up yet. There is a K&N filter in the airbox, so I didn't plan on changing it. As far as the coolant bottle location, that is where the air compressor for the front ARB is. Guess I might just have to go with the tube set-up just for the room.
  #5
Old 07-11-2001, 12:54 AM
Enjoying, Do you have any pics or diagrams of your set-up you can share?
  #6
Old 07-11-2001, 03:38 PM
Hey taz,
I need to setup my server space either on my ISP account or AOL account, I used to be very involved in web development and now I'm very lazy with it.
Anyway, I'll set this up ASAP and get a few photos up on the web. Do I loose points for a dirty engine?
Kent
Skids, XD9000I, Lights, Bumpers, CB/Ham/Scanner, Duo roof racks, ARB compressor, Duo-Optima's, 200 amp alt, and too much more to list!
These trucks rock!
  #7
Old 08-28-2001, 03:03 PM
Hey Taz (or anyone else),
I finally got photos of my duo-battery install. I swapped my red-top Optima into another car, putting an Interstate in it's place, but if you want me to post photos just let me know.
Kent
Need a lift REALLY badly!!
  #8
Old 08-28-2001, 04:55 PM
uplandhawaii's Avatar
uplandhawaii is an unknown quantity at this point
Here's the clickable for Enjoyinglife121
I'd like to see your set up, I've been cobbling pieces for a 2 battery set up but am not sure of how to do it. I've just ordered a ZENA underhood welder system and figured I should have another battery as back up.
Thanks...
<font color=blue>Stafford</font color=blue>
  #9
Old 08-28-2001, 04:59 PM
Hey AJ,
What happened to your sig pic?
Later...
  #10
Old 08-28-2001, 06:20 PM
Andytron is an unknown quantity at this point
This is an old post. Before he painted his truck cammo.
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
