ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeep-Mid-Sized
Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee
Old 11-21-2000, 06:21 PM
Default Engine cuts off
My '95 Cherokee occassionaly cuts off while being driven at normal cruising speeds. The engine (4.0L)just dies with no warning but easily restarts by putting it in neutral and turning the key. Otherwise it runs smooth with no problems. Anybody know what is causing this and how to fix it?
Old 11-22-2000, 12:44 AM
piaa_nissan's Avatar
piaa_nissan is on a distinguished road
Default Re: Engine cuts off
This problem is caused by your crank position sensor (cpk). It's located behind the rear of the valve cover on the bellhousing for the tranny. You can buy them at a parts store or a dealer. Its a small black cube with a wire that leads to a harness on your intake manifold. It's a real P.O.S. to change, mine was doing the same thing and it finally quit leaving me stranded forcing me to articulate myself to replace it.
http://www.skyboom.com/Robison
Off-Road Videos -
ATV Reviews -
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
