ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeep-Mid-Sized
Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee
Old 10-24-2009, 11:09 AM
Warthog's Avatar
Journeyman
Warthog is an unknown quantity at this point
Question HELP!!! Changed Alternator, Engine turns over but won't start
Hi,
Over here from the Short wheel base forum. I did a favour for my sister(always regret favours for family) and changed the dead alternator in her 91cherokee 4.0l. Now the engine cranks but won't start, it's turning over quickly, so I know the battery still has enough charge. I disconnected the battery over night as well just incase the computer had a code stuck in it or something. Tried it this morning and still the same thing. No check engine light or anything?
Any ideas?
Thanks in advance for the help.
__________________
88 YJ, 95 4.0l AX15, SOA w/1.5" RE, shackle reversal 35" Procomp XMT, 4.56s, F/open R/ARB, d44 highsteer & hi 9", 4 wheel discs, Sam's HD TB, 4:1 w\wide chain, OBA, 6 point cage
Future: HP d44, F/ARB, paint and body
Old 11-18-2009, 09:44 PM
Newbie
vegachris is on a distinguished road
Default possible problem
Hello, to what it sounds it is cranking, so it is not a battery, starter, or alternator issue. Second you need to find out if it you are getting fuel(there is a fuel purge valve on your fuel rail) if fuel squirts out you are getting fuel. Next you need to find out if you have spark, unplug a sparkplug wire and crank your jeep and see if you are getting spark, if there is no spark it can be a pick up coil (under your distributor cap), your ignition coil, your crankshaft position sensor, or your pcm. Most common on the 4.0 is the crank sensor it runs about 30 dollars and can be found on most parts stores. Please let me know how it went, good luck!
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
