ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeep-Mid-Sized
Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee
Old 06-20-2009, 09:18 PM
Stranger
WickedZJ is on a distinguished road
Default When warmed up ZJ struggles to stay running
I can start my j94 ZJ 5.2L in the morning fine, let it sit while I'm at work and it runs fine when I leave for lunch. When I go to leave home to go back to work it will idle real low around 500RPM or lower. Runs fine when I go to leave work. I went out today to do some running and since the motor stayed warm, every time I started it, it would try to stall, give it a little gas and it would idle low but run ok. Towards the end of the running it was idling so low it was shaking while trying to stay running without giving it gas. It was sitting for around 3 weeks till I could fix my Neutral Safety Switch and now it seems to run like crap.
Anyone have any ideas where to start looking to resolve this?
Old 06-21-2009, 04:22 PM
Stranger
78 f250 supercab is on a distinguished road
Default
Hey man, i got a similar problem with my 94 zj with the 4.0 though, when mine warms up it back fires and after a few minutes of backfirin it don't wanna stay runnin, it started with two problems, my cat guts clogged my muffler so i cut it off an ran it out the side, then found burnt O2 sensor wires, commen thing i've read about happening, i replaced my O2 and map sensor and cleared my computer, i don't know if my spark plugs would be the problem now though? from the backfiring?
What i would recommend for you, cuz my buddy has the same problem with his with the 5.2 is to have the computer checked out,
Old 06-21-2009, 09:34 PM
Stranger
Default
May have to do that. My brother in law had the same thing happen on his old ram with a 5.9. He said his was a TPS sensor went bad. I may pick one up just too see.
Old 07-07-2009, 12:11 AM
GeeAea's Avatar
GeeAea is an unknown quantity at this point
Default
If you have an EGR valve ..manipulate the vacuum to it when cold. It should effect it. If it doesn't, that may be your problem.
__________________
Gary L. Allan, Sr.
Pottstown, PA
If it ain't broke ..fix it 'til it is
  #5
Old 07-11-2009, 09:23 PM
Fred j Hemer is an unknown quantity at this point
Default
Check your fuel preasure!A failing fuel pump will cause this also.
__________________
91 jeep cherokee 270000 kms deceased
93 grand cherokee 335000 kms living
242 T case from a cherokee
  #6
Old 07-20-2009, 11:54 PM
dorfs is an unknown quantity at this point
Default
Your battery voltage is low. You lost all long term memories, idle adaptives, fuel adaptives, purge etc. Chances are if you drive your Jeep for a couple of miles, it will be fine, until you start it the next time (when the draw on the starter drops the battery voltage below 9.6v) and you loose your adaptives again. Charge or replace the battery.
  #7
Old 08-16-2009, 01:44 PM
krabysniper's Avatar
krabysniper is an unknown quantity at this point
Default
If it sat for a few weeks, with the sh!tty gas they sell nowadays, it is very possible you have a plugged or fouled injector. You could try pulling the plug wires one at a time and see if you find one that dosn't alter how it runs or causes the least change in the way it runs and that will most likely be the culprit injector. You could either have a service shop run some injector cleaner thru them, replace them all (expensive) or you could just try running some fuel injector cleaner thru the tank for the next 3 or 4 tanks of fuel and see if the problem clears up. I also agree it could be TPS or low voltage, but the voltage thing you should be able to tell by the battery gauge when you first get in and try to start it, if you had low voltage it would crank slowly and you would have noticed that I would think. Good luck and please respond letting us know what you figure out.
__________________
90 XJ 4.0 lift 4 1/2", 31 x 10 1/2 MT's
First piece of advice, free,
My opinion, free,
F'n with my family, YOUR LIFE
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
