dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee |
01-12-2009, 04:38 PM
|  | Stranger | | Join Date: Dec 2008 Location: Milwaukee
| | Willys Wagon brakes
Hi,
Just joined and this is my first posting. Great Forum!!
How do I remove the rear brake drums on a Willys wagon axle? I don't know the the year since it's a Frankinstien truck. It's a 1962 Ford econoline with Willys running gear.
Thanks for any help in advance.
John
01-13-2009, 09:35 AM
|  | Journeyman | | Join Date: Dec 2007 Location: Battle Ground Washington
most drum nrakes have a slot in the dust shield that you can back off the adjuster star wheels. if the shoes are grooved the drums wont come off untill the adjusters are backed way off.
01-13-2009, 02:47 PM
| | Way Outta Control | | Join Date: Sep 1999 Location: usa
Willys! Rare now.
Lockheed Brakes - a lost art.
Use the 2 cams on the back of the backing plate to back the shoes off - the regular adjusters.
If you see a big nut in the center of the drum, remove the cotter pin, then the nut, then the washer underneath. The threaded thing sticking out is the tapered axle. Remove and clean the axle key.
Then you'll need a puller - a big one that pulls on the studs and pushes on the axle end. Make sure you put it on even and tight. Then pull it off.
The drum will be stuck on the hub. The studs hold it on.
When putting it back on, clean and lube the tapered parts - axle and hub. DO NOT PUT THE HUB BACK ON WITH THE KEY IN PLACE. Slip the hub on over the axle all the way to seat it - make sure it's on all the way.
THEN, after the hub's on, line up the keyways in the axle and hub and slip the key in. Make sure you have the cut off corner on the key toward the center of the axle (away from you) and and pointing toward the axle, not the hub.
Putting it back together wrong you can lose a wheel or at least do lots of damage.
They never were decent brakes even when new. If you replace the linings, ask for the cheapie linings - not the "good" ones.
The so called "good ones" or "lifetime" are way to hard - they won't stop very well. The cheapies are soft, meant to wear fast - but they stop!
What are brakes for anyway?
__________________
Too many idiots on the SWB to bother with them.
01-13-2009, 04:51 PM
Guys,
Thanks for the detailed procedure. I need to replace the studs on the LH side because I busted them off because I would have never thought they would be LH thread DUH!!
Here is a picture of it.
John |
01-13-2009, 05:08 PM
Kool!
The old Willys wagons were often used for putting another body on it. I even put a 58 'Vette body on one.
Old '49-50's era Jeepsters were a popular swap.
__________________
06-16-2009, 11:04 AM
| | Stranger | | Join Date: Jun 2009 Location: Minnesota
| | More Willys Brake Help
Hello,
I have a 1960 Willys Wagon and I am having a HECK of a time removing the rear brake drum. I've used a slide hammer, a big puller (broke one), and even applied heat. It won't come off.
So, I searched and saw that below you mentioned to remove the axle key before removing the hub. How do you do that? I can't seem to get it out by wedging screwdrivers and small chisels along side it.
Any tips would be greatly appreciated... I'm highly frustrated.
Thanks,
Lee
06-17-2009, 03:54 AM
You won't get it that way. Soak it in PB Blaster overnight. Then try a STRONG magnet while you tap tap tap on the hub. It may jiggle out.
If it doesn't come off, use the correct axle puller and pull it off. Pull on the studs, not the drum.
If you are lucky, it'll come off with the hub.
Check closely once it's off - make sure it hasn't cracked or swelled the hub inside by the key. If it has, you need a new hub. If you don't replace it you could lose the wheel later on.
__________________
06-17-2009, 02:46 PM
| | Homemade puller?
Thanks much for the reply!!
What is the correct puller and where is the best place to find one?
Since I have a big puller and am on a budget, would it work if I took a thick piece of stock plate, cut the appropriate holes in it for the lugs, fastened it to the hub with the lug nuts, and then pulled on that plate with the big puller? The force would then be in the appropriate place...
Let me know your thoughts, please.
Thanks!
06-17-2009, 04:29 PM
As you suggested - probably.
Older rental yards have them. Keep your eyes open at garage sales too.
or you can buy one new - about $100.
__________________
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 02:43 AM. |
