dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee |
08-29-2008, 09:19 PM
|  | Aprentice | | Join Date: Aug 2007 Location: Kannapolis N.C
| | Cherokee brakes wont work
Whats up with the rear lights on my 2000 grand cherokee.Wiyh the running lights off the brake lights work fine,but turn on the lights and one goes out and the other goes bright.The third brake light stays on real dim.Gonna get me a ticket,any ideas????
__________________
1993 Jeep YJ,32x12.50 Mud Dawgs,9000LB Ramsey winch,2"body lift,long shackes
08-30-2008, 08:10 AM
|  | Keyboard Implanted | | Join Date: Mar 2003 Location: Holland
Sounds like a bad ground or a corroded connector somewhere.
__________________
HJ
If in doubt, add a bit more
Jamboree '94 stock 4.0 AX15 8.25
Cherokee Pioneer '88 i6 2-door 5 speed mostly stock put asleep
08-30-2008, 11:49 AM
All the other electrical systems work great.Does anyone know if there is a ground in the rear,under the hood seems fine.
__________________
08-30-2008, 07:16 PM
| | Aprentice | | Join Date: Sep 2002 Location: AZ, near Tucson
The brake lights are grounded neat the light units, inside the rear fenders. You can remove the rear light units and by inspection find out which part should be grounded (the part that connects to the outer metal part of the bulbs. Then you can just make a new ground to that part. You can use clip leads (wires with alligator clips on them; you can get them at Radio Shack) to try out your repair before making a permanent one.
You might even be able to see where the fault is, but there's nothing wrong with adding another ground, as long as you ground the right part.
Good luck
__________________
Don't force it - - get a bigger hammer!!
08-31-2008, 03:23 PM
These bulbs are in a twist lock and theres noway of getting to the ground side of the bulb.They are they flat plug in style.
__________________
08-31-2008, 11:17 PM
You have to remove the whole tail light assembly and look at the back of it. All the light bulbs will have a ground; all the grounds will go to the same place.
On G. M trucks with the push-in lights I had a lot of trouble with the plastic part of the sockets melting and creating a bad connection where the bulbs plug in. You might take a look at that.
__________________
09-06-2008, 08:25 PM
The grounding did not help,but I'am going to look at it again more this weekend.
__________________
11-03-2008, 07:51 PM
Fixed them,the cheap plastic light sockets were cracked and when the bulbs are pushed in the connectors pushed in and no contact.Got a set of replacement lights off e-bay for 60 bucks,cheaper than the ticket....
__________________
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 12:52 PM. |
