OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep Forums > Jeep-Mid-Sized
Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee
Old 06-15-2008, 10:09 PM
Stranger
shane47 is on a distinguished road
Default Brake shoe/pad recommendations?
Does anyone have brake pads & shoes that they would recommend for my 97 Cherokee Sport? Pretty much everything is stock on the Jeep, and the majority of the driving is on paved roads, with occasional off-roading (dirt roads & pastures, no trail driving). I'll likely also put new rotors on the front, so any rotor recommendations are welcome. Thanks in advance!
Old 06-15-2008, 10:32 PM
wsmm is an unknown quantity at this point
Default Pads. Shoes & Rotors
I just use regular pads or shoes from either Advance Auto Parts, Autozone or Auto Value. Just remember harder composition for pads or shoes will wear the rotors or drums more. As far as rototrs as long as there is no deep scoring, and if there true (I use a dial guage) I just brake the glaze on the rotots with sand paper and re-install. THeone thing you wnat to be sure t do is lubricate hte pins for the disk calipers so that they don't hang up.
Good luck,
Bill
Old 06-18-2008, 08:05 AM
Stranger
Default
Thanks for the input, Bill, and good reminder about lubing the pins.
Old 06-22-2008, 11:38 PM
Aprentice
heavyequipment is an unknown quantity at this point
Default
I had a brake squeal I couldn't get rid of by any means I could think of. When I replaced the pads with ceramic ones, it went away. (The brakes work quite well, by the way...)
__________________
Don't force it - - get a bigger hammer!!
  #5
Old 06-23-2008, 05:03 PM
NIX's Avatar
NIX NIX is offline
Carpal \'Tunnel
NIX is an unknown quantity at this point
Default
Apply some coppergrease on the backside of the pads were they touch the calper and piston.
__________________
HJ
If in doubt, add a bit more
Cherokee Pioneer '88 i6 2-door 5 speed mostly stock
  #6
Old 06-23-2008, 05:27 PM
Aprentice
Default
I think coppergrease must be an equivalent of never-sieze, which I use for a lot of things. For brake lube I use Permatex Disc Brake lube. It is a synthetic grease that comes in a jar with a brush, similar to the never-sieze jar. Lubrication at these points is important, both to quell noise and to prevent rust. I use never-sieze on all the threads, and disc brake lube on sliding surfaces.
__________________
Search this Thread:
Advanced Search
Need Gas Mileage & Power?-
Off-Road Videos -
ATV Reviews -
