| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee |
06-15-2008, 10:09 PM
| | Stranger | | | Join Date: Jun 2008 Location: Southeast US
| | Brake shoe/pad recommendations? Does anyone have brake pads & shoes that they would recommend for my 97 Cherokee Sport? Pretty much everything is stock on the Jeep, and the majority of the driving is on paved roads, with occasional off-roading (dirt roads & pastures, no trail driving). I'll likely also put new rotors on the front, so any rotor recommendations are welcome. Thanks in advance! |
06-15-2008, 10:32 PM
| | Enthusiast | | | Join Date: Sep 1999 Location: Mid Michignan
| | Pads. Shoes & Rotors I just use regular pads or shoes from either Advance Auto Parts, Autozone or Auto Value. Just remember harder composition for pads or shoes will wear the rotors or drums more. As far as rototrs as long as there is no deep scoring, and if there true (I use a dial guage) I just brake the glaze on the rotots with sand paper and re-install. THeone thing you wnat to be sure t do is lubricate hte pins for the disk calipers so that they don't hang up.
Good luck,
Bill |
06-18-2008, 08:05 AM
| | Thanks for the input, Bill, and good reminder about lubing the pins. |
06-22-2008, 11:38 PM
| | Aprentice | | | Join Date: Sep 2002 Location: AZ, near Tucson
| | I had a brake squeal I couldn't get rid of by any means I could think of. When I replaced the pads with ceramic ones, it went away. (The brakes work quite well, by the way...)
__________________
Don't force it - - get a bigger hammer!!
06-23-2008, 05:03 PM
|  | Carpal \'Tunnel | | | Join Date: Mar 2003 Location: Holland
| | Apply some coppergrease on the backside of the pads were they touch the calper and piston.
__________________
HJ
If in doubt, add a bit more
Cherokee Pioneer '88 i6 2-door 5 speed mostly stock
06-23-2008, 05:27 PM
| | I think coppergrease must be an equivalent of never-sieze, which I use for a lot of things. For brake lube I use Permatex Disc Brake lube. It is a synthetic grease that comes in a jar with a brush, similar to the never-sieze jar. Lubrication at these points is important, both to quell noise and to prevent rust. I use never-sieze on all the threads, and disc brake lube on sliding surfaces.
__________________
| | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! | All times are GMT -5. The time now is 01:41 AM. |
