I installed a 3-row radiator Labor Day weekend in '05 when my 2-row cracked. My Jeep used to run hot all the time when it was hot outside, especially when sitting in traffic, drive-thru, etc. for a long time and the A/C on. So far, it doesn't get hotter than 210, even though it feels like that in NC lately. I drove to the Buffett concert ~3pm 2 days ago, fully loaded, and sitting in traffic getting to the lot and it never got hotter than 210. I also was going to upgrade to a 3-row since I added a towing hitch.
I added a 2" lift last summer. Yeah, I know it's not much but I couldn't afford putting much more. The only real issue was my front shock bushing, in the engine compartment above the shock towers, they kept shredding and then I would get a wobbling going anywhere from 60-70 MPH, plus the metal banging. I bought poly bushings (cheaper price than the rubber ones!) and both of those problems stopped.
Over Memorial Weekend I replaced my oil pan gasket, rear oil seal, and oil filter adapter. I would lose a quart of oil anywhere between 3 weeks and a month, depending on how much highway (fast) driving I would do. The top part of the rear oil seal was a pain to get out, but other than that, the oil pan just felt like it had a ton of bolts. So far, no leaks.
About 6 months after I bought my current 96 XJ SE in 2003, I found a leak in the original radiator about halfway down and in the middle so I replaced it with a new 2 pass one, along with a new fan shroud. In 2006, we bought a large pop up camper and I wanted to make sure I had enough cooling capacity to tow the camper without overheating the engine or the auto transmission. Since I had a new 2-pass radiator, I opted for a transmission cooler installation. So we arrived at the same condition thru different means.
__________________
96 XJ SE 2door, 4.0, AW-4 w/ 6 pass cooler, NP231, stock height/tires, Valley 1 1/4" receiver, 7 pin harness, Monroe air shocks.
Another update: water pump seal went out recently, replaced it and put a new 195* Thermostat in. Now, the XJ runs even cooler than when I put the 3-row radiator in.
Old thermostat used to open and temp peaked after the 210* mark and then cooled back down, now it opens prior to the 210* mark. Not sure what thermostat was put in before I bought it back in '02.
Now just about every major thing has been replaced since I bought it: starter, alternator, radiator, water pump. Engine is still hauling ass at over 240,000 miles.
The lift is working well now that I put the poly shock tower bushings in - the rubber ones would shred.
Off-Road Videos - Check out over ten years of extreme 4x4 action, product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it's all here. Rate them, share them and upload your own.
ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles.
