OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep Forums > Jeep-Mid-Sized
Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee
Old 06-09-2008, 05:29 AM
BFA's Avatar
BFA BFA is offline
Journeyman
BFA is an unknown quantity at this point
Default Update on Jeep: 3-row radiator, lift, oil leaks
I installed a 3-row radiator Labor Day weekend in '05 when my 2-row cracked. My Jeep used to run hot all the time when it was hot outside, especially when sitting in traffic, drive-thru, etc. for a long time and the A/C on. So far, it doesn't get hotter than 210, even though it feels like that in NC lately. I drove to the Buffett concert ~3pm 2 days ago, fully loaded, and sitting in traffic getting to the lot and it never got hotter than 210. I also was going to upgrade to a 3-row since I added a towing hitch.
I added a 2" lift last summer. Yeah, I know it's not much but I couldn't afford putting much more. The only real issue was my front shock bushing, in the engine compartment above the shock towers, they kept shredding and then I would get a wobbling going anywhere from 60-70 MPH, plus the metal banging. I bought poly bushings (cheaper price than the rubber ones!) and both of those problems stopped.
Over Memorial Weekend I replaced my oil pan gasket, rear oil seal, and oil filter adapter. I would lose a quart of oil anywhere between 3 weeks and a month, depending on how much highway (fast) driving I would do. The top part of the rear oil seal was a pain to get out, but other than that, the oil pan just felt like it had a ton of bolts. So far, no leaks.
__________________
'92 XJ Briarwood 4.0L HO
Old 06-10-2008, 09:50 PM
xjy173's Avatar
Carpal \'Tunnel
xjy173 is an unknown quantity at this point
Default
About 6 months after I bought my current 96 XJ SE in 2003, I found a leak in the original radiator about halfway down and in the middle so I replaced it with a new 2 pass one, along with a new fan shroud. In 2006, we bought a large pop up camper and I wanted to make sure I had enough cooling capacity to tow the camper without overheating the engine or the auto transmission. Since I had a new 2-pass radiator, I opted for a transmission cooler installation. So we arrived at the same condition thru different means.
__________________
96 XJ SE 2door, 4.0, AW-4 w/ 6 pass cooler, NP231, stock height/tires, Valley 1 1/4" receiver, 7 pin harness, Monroe air shocks.
Proud Papa of a US Marine
Old 06-12-2008, 12:16 AM
BFA's Avatar
BFA BFA is offline
Journeyman
Default
That's cool. I thought about doing that as well, but 1 project at a time.
__________________
Old 08-18-2008, 08:35 AM
BFA's Avatar
BFA BFA is offline
Journeyman
Default
Another update: water pump seal went out recently, replaced it and put a new 195* Thermostat in. Now, the XJ runs even cooler than when I put the 3-row radiator in.
Old thermostat used to open and temp peaked after the 210* mark and then cooled back down, now it opens prior to the 210* mark. Not sure what thermostat was put in before I bought it back in '02.
Now just about every major thing has been replaced since I bought it: starter, alternator, radiator, water pump. Engine is still hauling ass at over 240,000 miles.
The lift is working well now that I put the poly shock tower bushings in - the rubber ones would shred.
__________________
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
In the Business of Off-Road?-
If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
