OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep Forums > Jeep-Mid-Sized
Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee
Old 05-07-2008, 08:10 PM
Stranger
morosemofer is on a distinguished road
Default 93 cherokee sport i6 4L
i have a new issue with my jeep. as of about a week ago my battery gauge has been telling me that i am only running ten volts. when it is idling i put my multimeter on the battery and it read almost 14volts. i recently put a new alternator on and thought that maybe it was my belt was a little loose. i have tightened the tensoin bolt and it still didnt change the gauge. anyone who can shed some light on this situation please do so.
Old 05-08-2008, 12:47 PM
NIX's Avatar
NIX NIX is offline
Carpal \'Tunnel
NIX is an unknown quantity at this point
Default
Probably some resistance in the wire or connector to the gauge or a bad gauge. I wouldn't give it much attention. If it starts to start badly, then you have a problem. Measuring at the battery was the right thing to do.
__________________
HJ
If in doubt, add a bit more
Cherokee Pioneer '88 i6 2-door 5 speed mostly stock
Old 05-10-2008, 06:57 PM
Aprentice
heavyequipment is an unknown quantity at this point
Default
What Nix says, or a bad instrument panel ground. Any other odd gauge readings? Do the panel lights work normally?
__________________
Don't force it - - get a bigger hammer!!
Old 05-12-2008, 08:49 PM
xjy173's Avatar
Carpal \'Tunnel
xjy173 is an unknown quantity at this point
Default
I would check the grounding strap that goes from the firewall to the engine block. The strap may be corroded or partially broken. Your dash gauge is probably indicating the voltage to all the dashboard devices. Since your battery and alternator are good, as evidenced by the 14 volt reading at the battery, then it is either a bad ground situation or a defective gauge. I'd bet it's a bad ground.
HTH Good Luck!!
__________________
96 XJ SE 2door, 4.0, AW-4 w/ 6 pass cooler, NP231, stock height/tires, Valley 1 1/4" receiver, 7 pin harness, Monroe air shocks.
Proud Papa of a US Marine
  #5
Old 08-18-2008, 08:46 AM
BFA's Avatar
BFA BFA is offline
Journeyman
BFA is an unknown quantity at this point
Default
My alternator seems to read a lower voltage after it's been driven around beforehand.
Key thing to look for is when it's reading low, check to see if your turn signal seems slower than usual. That happened to me, especially at night with the lights on (head and fog) and the A/C blasting. I think also blasting the stereo with a sub doesn't help the situation as well.
__________________
'92 XJ Briarwood 4.0L HO
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
In the Business of Off-Road?-
If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
