| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee |
05-07-2008, 08:10 PM
| | Stranger | | | Join Date: Mar 2008 Location: florida
| | 93 cherokee sport i6 4L i have a new issue with my jeep. as of about a week ago my battery gauge has been telling me that i am only running ten volts. when it is idling i put my multimeter on the battery and it read almost 14volts. i recently put a new alternator on and thought that maybe it was my belt was a little loose. i have tightened the tensoin bolt and it still didnt change the gauge. anyone who can shed some light on this situation please do so. |
05-08-2008, 12:47 PM
|  | Carpal \'Tunnel | | | Join Date: Mar 2003 Location: Holland
| | Probably some resistance in the wire or connector to the gauge or a bad gauge. I wouldn't give it much attention. If it starts to start badly, then you have a problem. Measuring at the battery was the right thing to do.
__________________
HJ
If in doubt, add a bit more
Cherokee Pioneer '88 i6 2-door 5 speed mostly stock
05-10-2008, 06:57 PM
| | Aprentice | | | Join Date: Sep 2002 Location: AZ, near Tucson
| | What Nix says, or a bad instrument panel ground. Any other odd gauge readings? Do the panel lights work normally?
__________________
Don't force it - - get a bigger hammer!!
05-12-2008, 08:49 PM
|  | Carpal \'Tunnel | | | Join Date: Sep 1999 Location: Philadelphia, Pa.
| | I would check the grounding strap that goes from the firewall to the engine block. The strap may be corroded or partially broken. Your dash gauge is probably indicating the voltage to all the dashboard devices. Since your battery and alternator are good, as evidenced by the 14 volt reading at the battery, then it is either a bad ground situation or a defective gauge. I'd bet it's a bad ground.
HTH Good Luck!!
__________________
96 XJ SE 2door, 4.0, AW-4 w/ 6 pass cooler, NP231, stock height/tires, Valley 1 1/4" receiver, 7 pin harness, Monroe air shocks.
Proud Papa of a US Marine
08-18-2008, 08:46 AM
|  | Journeyman | | | Join Date: Mar 2003 Location: NC
| | My alternator seems to read a lower voltage after it's been driven around beforehand.
Key thing to look for is when it's reading low, check to see if your turn signal seems slower than usual. That happened to me, especially at night with the lights on (head and fog) and the A/C blasting. I think also blasting the stereo with a sub doesn't help the situation as well.
__________________
'92 XJ Briarwood 4.0L HO
| | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! | All times are GMT -5. The time now is 08:12 PM. |
