OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep Forums > Jeep-Mid-Sized
Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee
Old 04-30-2008, 02:37 PM
Stranger
jeririah is on a distinguished road
Default Distributer/Cam sensor in wrong?
I was replacing the battery cables on my 1993 Jeep Cherokee with 4.0 and accidently cut the wire to the pickup coil going to the distributer. I replaced the pickup coil but it would not start. So I also eventually replaced the ignition coil, and the relay in the power distribution box. I finally gave up and towed it to the local auto repair shop. After $270.00 they said the new pickup coil that I had bought and put into the distributer was bad and they replaced it with a new one. They also replaced the spark plugs. Well now the Jeep runs with about half the power, has a loud tapping noise coming from the engine, and is overheating. It took forever to get it up to speed to bring it home and I had to turn the heater on high to keep the temp. gauge from red lining. They claimed the cam sensor was good and put the pickup coil to test which showed it was bad. My question is could they have installed the cam sensor in wrong or the distributer in wrong? I know the distributer had to be at top dead center and the slot at the bottom had to point a certain way, and the rotor pointing a certain way before installing it. This jeep had the usual lifter tapping noise before but NEVER this loud rapping noise coming from it now. It also never overheated and had lots of pickup and go for its age. I can't believe a simple pickup coil replacement would cause this much trouble. Any help would be appreciated.
Old 05-02-2008, 12:49 PM
Carpal \'Tunnel
Andytron is an unknown quantity at this point
Default
How is the idle? Smooth or rough?
__________________
"Every form of refuge has it's price."
Old 05-02-2008, 03:39 PM
Stranger
Default
It is smooth and it starts right up. You don't know there is a problem into you put it into gear and step on the gas and feel how powerless it is. You have to almost floor it to get it going. Thanks.
Old 05-02-2008, 03:41 PM
Stranger
Default
Oh I forgot the loud rapping noise is there once it starts up too. It dominates all sound when idleing.
  #5
Old 05-02-2008, 05:17 PM
NIX's Avatar
NIX NIX is offline
Carpal \'Tunnel
NIX is an unknown quantity at this point
Default
Sounds to me the shop did a bad job making your engine worse than it was before. Take it back to them.
__________________
HJ
If in doubt, add a bit more
Cherokee Pioneer '88 i6 2-door 5 speed mostly stock
  #6
Old 05-05-2008, 06:53 PM
maxxedout's Avatar
Newbie
maxxedout is on a distinguished road
Default
Could they have the dist 180 out.If you bring it up to TDC on #1 cyl the rockers will be loose,if not rotate it another 180.
__________________
1993 Jeep YJ,32x12.50 Mud Dawgs,9000LB Ramsey winch,2"body lift,long shackes
  #7
Old 05-05-2008, 07:56 PM
I am in the CPU
RRich is an unknown quantity at this point
Default
If it was 180 out it won't run at all.
But - Betcha they got the plug wires mixed up.
I wouldn't drive it like it is - either fix it yourself or have it towed back to them. Have them have it towed - the tow bill should be on them.
"""""I can't believe a simple pickup coil replacement would cause this much trouble. """""
It's not the simple pick-up coil replacement - it's the incompetent fools that did it. They should have driven it before they gave it back to the customer.
__________________
If oil company profits of 4% are obscene, then what do you call the Fed's 15% tax on them?
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
In the Business of Off-Road?-
If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
