OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep Forums > Jeep-Mid-Sized
Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee
Old 04-18-2008, 05:56 PM
Aprentice
heavyequipment is an unknown quantity at this point
Default drivability problem
My brother-in-law's '87 Cherokee 4.0L surges or misses (he says it bucks) around 2500-2800 RPM just cruising or slowing down. The throttle position sensor has been replaced with a new one, and the MAP sensor was swapped with one from my own Cherokee that runs perfectly. I haven't driven it myself yet (he lives a couple of hours away) so I'm not quite sure if it's engine related or if the (auto) trans is doing something odd.
If anyone has seen something like this, I'd like to hear about it...
Thanks
__________________
Don't force it - - get a bigger hammer!!
Old 04-25-2008, 11:48 AM
Aprentice
Default
I finally got to test drive it yesterday. It seems to be shifting in and out of lockup between 2000-2200 RPM at part throttle.
It's got me stumped, so far. But I got a factory shop manual delivered just yesterday...
__________________
Old 04-25-2008, 04:23 PM
NIX's Avatar
NIX NIX is offline
Carpal \'Tunnel
NIX is an unknown quantity at this point
Default
Sounds to me like a TCU problem.
__________________
HJ
If in doubt, add a bit more
Cherokee Pioneer '88 i6 2-door 5 speed mostly stock
Old 04-25-2008, 05:33 PM
Aprentice
Default
Thanks, NIX...
I was just thinking that after seeing another post about a Grand Cherokee. Someone also suggested looking at the engine and trans mounts.
Luckily, I have a spare TCU if the one from a 92 2-wheel drive will fit. I'm going to try that at the first opportunity.
__________________
  #5
Old 04-26-2008, 02:24 AM
NIX's Avatar
NIX NIX is offline
Carpal \'Tunnel
Default
If they are both AW4 trannies chances it might work.
__________________
HJ
  #6
Old 05-23-2008, 03:31 PM
Aprentice
Default
They are both AW4's, but the TCU is different. The plug won't fit. Studying the factory manual, I noticed that there is a brake switch that disables lockup when the brake is applied. I told my brother-in-law to test it by slightly depressing the brake pedal when it starts acting up. He did, and it quit jerking. I think this isolates the lockup control as the problem area. Could be the brake switch, the TCU, or maybe the speed sensor. Next time I see it I'll put in a temporary override switch to eliminate (or confirm) the brake switch as the problem.
  #7
Old 06-04-2008, 08:19 PM
JeepDawg's Avatar
JeepDawg is on a distinguished road
Default
I was just about to suggest the brake light switch....
Two possible problems....
1. Out of adjustment
2. Brake pedel spring is broken.
You should have about 1" of travel before the brake light comes on.
BTW...The reason for that is so that the computer does not keep the converter locked up as you brake and slow down. With the converter locked, it would kill the engine when you came to a stop.
__________________
AKA DDawg16
84 CJ7, SOA, 5.7LTBI, 4L60E, 32"x11.5, 4.10 gears, F/Det, R/ARB
89 Cherokee, 4.5" Lift, R/D44, 31"x11.5
Both Never Finished
  #8
Old 06-04-2008, 11:05 PM
Aprentice
Default
I told my brother-in-law to depress the brake pedal a little when the surging starts. He did, and the surging stopped, proving that the transmission had been going in and out of lockup.
I had plans to test whether the brake light switch, the speed sensor, or the TCU was acting up, but now he tells me it doesn't do it anymore. If it sstarts acting up again, maybe we'll learn something new. I've learned a lot so far...
__________________
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
In the Business of Off-Road?-
If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
