| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee |
04-16-2008, 07:01 PM
| | Stranger | | | Join Date: Apr 2008 Location: Las Vegas
| | 92 Cherokee- grinding noise from left front wheel I have a 92 cherokee that just recently developed a grinding noise from what sounds like the left front wheel. It's a noise similar to the noise you get when you let your brake pads run all the way down the the rivets. Funny thing is, it only happens when you step on the brakes, or when you make a right hand turn (without your foot on the brake). I checked the brakes, and they are good. I also just replaced the left front bearing assembly (cuz I was sure that's what it was), but it didn't help. Anyone have any ideas? |
04-17-2008, 09:41 PM
| | Carpal \'Tunnel | | | Join Date: Sep 1999 Location: Near Chicago, IL
| | How is the front axle u-joint on that side?
__________________
"Every form of refuge has it's price."
04-18-2008, 09:33 AM
| | Quote:
Originally Posted by Andytron How is the front axle u-joint on that side? |
I don't know. It hadn't even crossed my mind that a U Joint could make the kind of noise. I guess I should have mentioned that I buried the jeep up to the bottom of the doors in sand about a week before this noise started. |
04-20-2008, 12:10 PM
|  | Aprentice | | | Join Date: Mar 2003 Location: NC
| | That happened to me the last couple days, I thought it was time to change the front brakes. Well, there was still a little bit of pad left but I changed them anyway and the noise remained when I went for a test drive.
I braked a couple of times pretty hard and it seems that one of the back wheels locked up because the Jeep fishtailed (the ABS has always worked otherwise), but after braking a couple of times like that, the noise and wheel lockups went away.
I am going to check out the drums and see if those pads need replacing or if there is some other issue.
__________________
'92 Jeep Cherokee Briarwood 4.0 HO
04-21-2008, 07:19 PM
| | Sand is really hard on bearings, u-joints and such. It gets stuck in the grease and can grind them up.
__________________
| | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! | All times are GMT -5. The time now is 03:53 PM. |
