99 Grand Oil Sending Pressure Sending Unit? - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeep-Mid-Sized
Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee
Old 01-15-2008, 12:19 PM
38-72
Default 99 Grand Oil Sending Pressure Sending Unit?
I have a 1999 Grand with the in-line 6 engine, and I need the find the oil pressure sending unit on the engine block. Where is it located?
Old 01-15-2008, 02:15 PM
NIX's Avatar
NIX NIX is offline
NIX is an unknown quantity at this point
Default
Next to the oil filter. At least on my Xj's i6 it is.
__________________
HJ
If in doubt, add a bit more
Jamboree '94 stock 4.0 AX15 8.25
Cherokee Pioneer '88 i6 2-door 5 speed mostly stock put asleep
Old 01-16-2008, 01:17 AM
Stranger
716pro is on a distinguished road
Default
Not to hijack your thread but,Now that that is answered what is the idle oil pressure supposed to be in psi? what about under load? Please answer, just rebuilt inline 6 and think oil pressure
might be low, its at 40 when idling, and around 58-59 when giving it good gas. Is that normal?
Old 01-16-2008, 03:03 AM
NIX's Avatar
NIX NIX is offline
Default
Yes. Mine varies from 20 -60. You even don't have to worry when it's 5 at idle and 20 at 3000 rpm. sometimes the sensors are not that accurate, sometimes with thicker oil the pressure is a bit higher than with thinner oil. No problem. An i6 can do fine with some minor wear.
Start worrying when the pressure is only 5 at 3000 rpm and zero at idle, even after replacing the sensor. You're facing a rebuild then (worn bearings and rods), but I assume you would also have other issues at that time.
__________________
HJ
  #5
Old 01-16-2008, 12:57 PM
krabysniper's Avatar
krabysniper is an unknown quantity at this point
Default
Rule of thumb, even in racing circles, is 10 psi for every 1000 rpm of engine speed. More is better to an extent, less is not good at all. Yours is outstanding, don't worry about it.
__________________
90 XJ 4.0 lift 4 1/2", 31 x 10 1/2 MT's
First piece of advice, free,
My opinion, free,
F'n with my family, YOUR LIFE
  #6
Old 01-22-2008, 03:33 PM
38-72
Default Still looking for oil pressure sending unit
Quote:
I checked the area around the oil filter. Nothing to be found there. So, I am still looking for the oil pressure sending unit. Anyone else have a suggestion as to where to look next?
  #7
Old 01-22-2008, 04:30 PM
NIX's Avatar
NIX NIX is offline
Default
Right from the oilfilter you see the silver thing. That's the oil pressure sending unit. It's on the oilfilter stud.
http://img156.imageshack.us/img156/8...toffwegja0.jpg
__________________
HJ
  #8
Old 01-27-2008, 03:28 PM
38-72
Default
Thanks for the photo, but my engine doesn't have anything around the oil filter. It doesn't even have a conventional distributor - it’s electronic.
  #9
Old 01-27-2008, 03:59 PM
NIX's Avatar
NIX NIX is offline
Default
Try to make some pics from different sides and angles. The thing must be somewhere.
__________________
HJ
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
