dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee |
01-06-2008, 02:59 AM
| | | Tires On-Road Cherokee
Hey people, I have a 2001 Cherokee and was wondering about available on-road tires. For two years I've been sliding around on the road's slightest bit of moisture or foliage like I'm on ice or still have my offroad tires on. I was wondering what would be a good road tire to purchase for the vehicle and I am not just considering a rain tire. I also would like a lighter tred or more low profile for traction in dry conditions. A rain tire usually solves the issue in the rain but i would also like something that doesn't make my steering float or bounce on dry pavement as much. I have a pick up also but I cant use it for much other than hauling.
01-06-2008, 12:54 PM
|  | Can't Get Enough | | Join Date: Dec 2006 Location: S. CA
I'm assuming you have a stock Cherokee and don't go off-road. (if so, we need to fix that....)
I've been running AFG AT's for years and have not had any issues wet or dry. VEry good traction. I would avoid the Pro-Comp tire. Good traction but they tend to ride rough.
If you want to improve the look slightly with no extra expense, go with a 30'x10.50'. It will give you a slightly better look and not have any adverse effect on driveability.
__________________
AKA DDawg16
84 CJ7, SOA, 5.7LTBI, 4L60E, 32"x11.5 (35's on order), 4.10 gears, F/Det, R/ARB, Full Roll Cage,
D44 Flat top in progress...
01-06-2008, 05:56 PM
|  | Carpal \'Tunnel | | Join Date: Sep 1999 Location: Philadelphia, Pa.
Right now, I have Cooper Discoverer ATRs size P215/75R-15 on my stock height XJ with 15x7 steel rims. They are have very good traction dry, rain, snow and ice. I tow a 3200lb. pop up camper with the Jeep and I do some light off roading also. I bought them at R.S. Strauss at @ $50.00 per tire.
__________________
96 XJ SE 2door, 4.0, AW-4 w/ 6 pass cooler, NP231, stock height/tires, Valley 1 1/4" receiver, 7 pin harness, Monroe air shocks.
Proud Papa of a US Marine
01-07-2008, 12:11 PM
| | Stranger | | Join Date: Jul 2004 Location: Jersey Shore, NJ USA
Firestone Destination AT has my vote. Have them on my '95 ZJ and stick like glue to wet and dry pavement.
__________________
1995 ZJ Laredo Grand Cherokee 4-Liter Select-Trac
1989 XJ Laredo Cherokee 4-Liter Select-Trac - SOLD Good Bye Old Friend | | Thread Tools | | | | Display Modes | Linear Mode |
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 06:56 PM. |
