ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeep-Mid-Sized
Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee
Old 01-06-2008, 01:37 AM
deathshead
Default blinker problem
I already posted a question about my steering collom problem. I finaly got it appart and repaired but the original problem of my blinkers not working still persists. all fuses are fine and the 4 ways work. any ideas?
Old 01-06-2008, 12:49 PM
JeepDawg's Avatar
JeepDawg is on a distinguished road
Default
By '4-ways', I assume you mean the emergency blinkers? That is actually a good way to test the bulbs...if they all light, then they are ok.
As you most likely know, the blinker depends on the current draw to the bulb for proper operation...if one is out, the current is less or non at all, hence, the blinker will not switch on that one side.
With that said....I was troubleshooting an issue with the blinkers on my jeep a while back...bulbs good...etc. I 'assumed' that if it blinked in one direction, if the bulbs were good on the other side, it would blink there as well. Well....it ended up being the blinker....not sure why, but replacing it restored both turn signal sides to proper operation. In relative terms, flashers are cheap....especially if you have already spent several hours troubleshooting the problem.
One last thing....Because your jeep is designed to work with a trailer, the wiring in the rear is a bit different than typical vehicles. Make sure you don't have any shorts back there where the trailer connector is.
__________________
AKA DDawg16
84 CJ7, SOA, 5.7LTBI, 4L60E, 32"x11.5 (35's on order), 4.10 gears, F/Det, R/ARB, Full Roll Cage,
D44 Flat top in progress...
Old 01-07-2008, 03:58 AM
NIX's Avatar
NIX NIX is offline
NIX is an unknown quantity at this point
Default
What year is your XJ? My '88 has 2 different blinker relays. 1 for emercency, 1 for direction. I had to replace both of them, but it worked for me that I switched them for a while to show the direction at least. Mine were put in the fusepanel left from the pedals. It's the round things.
No idea if you can get the relays that you can easily connect just by plugging them in. Ik had some relays (from the junkyard) that I had to ground and put some wires and connectors on, to get them to work. But they are doing fine now.
__________________
HJ
If in doubt, add a bit more
Jamboree '94 stock 4.0 AX15 8.25
Cherokee Pioneer '88 i6 2-door 5 speed mostly stock put asleep
Old 01-12-2008, 02:24 PM
deathshead
Default
I found the problem after replacing the blinker switch, the blinkers still did not work. so I got to lookin around and found that the blinker terminal in the fuse box was damaged. the fuse was wiggling just enough to brake the connection. thanks for your help though
  #5
Old 01-13-2008, 11:37 AM
JeepDawg's Avatar
Default
And thanks for posting the actual fix.....adds to the knowledge base...
__________________
AKA DDawg16
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
