dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee |
10-10-2007, 12:02 PM
| | Stranger | | Join Date: Oct 2007 Location: Buffalo, NY
| | Need Help on engine compatibility Jeep 4.0L
Hello, new here and wanted to first say hello. Now thats out of the way I have a problem. I bought a 1999 Jeep Grand Cherokee with a rod knock for cheap, I am having trouble tracking down an engine. The 99 Grand Cherokee has the Coil pack not distributor setup, so every motor I find that is a 99 has Distributor not coil. Will this motor accept the crank position sensor in place of the Distributor? I have also heard that a 97,98 4.0L engine will also fit, are the motor mount locations the same? PLEASE help, I have been searching for over a week on compatibility of these engines and have found no definite answers.
10-10-2007, 12:30 PM
|  | Can't Get Enough | | Join Date: Dec 2006 Location: S. CA
Mechanically, I believe they are going to be the same. Look down on the right side where the dist 'would' be and I'm sure you will see the hole plugged up or something there.
__________________
AKA DDawg16
84 CJ7, SOA, 5.7LTBI, 4L60E, 32"x11.5 (35's on order), 4.10 gears, F/Det, R/ARB, Full Roll Cage,
D44 Flat top in progress...
10-10-2007, 01:21 PM
I understand that there will be a hole there for the dizzy but will the CPS fit in there and work?
10-10-2007, 01:35 PM
|  | Keyboard Implanted | | Join Date: Mar 2003 Location: Holland
The CPS is at the bell housing at all types. It regulates the ignition timing and injector timing. Do you perhaps mean the cam sensor in the older types distributor? This one makes sure the CPS is not 360 degrees wrong.
If you want to be sure, pull your Cam sensor and make a pic. It would surprise me if something was different in the gear inside the engine.
__________________
HJ
If in doubt, add a bit more
Jamboree '94 stock 4.0 AX15 8.25
Cherokee Pioneer '88 i6 2-door 5 speed mostly stock put asleep
10-10-2007, 02:14 PM
^Yes I meant the Cam sensor, thank you for clearing that up.
10-10-2007, 05:33 PM
| | Quote:
Originally Posted by JeepDawg Mechanically, I believe they are going to be the same. Look down on the right side where the dist 'would' be and I'm sure you will see the hole plugged up or something there. | Mechanically they should be the same but will the motor mounts be in the same location?
10-10-2007, 05:58 PM
To my knowledge the 4.0 motormounts never changed.
__________________
HJ
10-10-2007, 06:05 PM
I REALLY need a positive answer. I am about to buy a 98 4.0L engine for my 99 that has coil pack not dist. Please someone has to know.
10-10-2007, 11:10 PM
| | Stranger | | Join Date: Sep 2007 Location: minnesota
| | Quote:
Originally Posted by 716pro I REALLY need a positive answer. I am about to buy a 98 4.0L engine for my 99 that has coil pack not dist. Please someone has to know. | anything before 99 will not be compatible to your grand. head, intake, hoses, waterpump, acc locations are all different. your best bet is to find a 99 or newer motor.
10-11-2007, 09:04 AM
| | Quote:
Originally Posted by xjpaukert anything before 99 will not be compatible to your grand. head, intake, hoses, waterpump, acc locations are all different. your best bet is to find a 99 or newer motor. | Are you positive? I have heard from a few sources that it will fit with my intake and exhaust manifolds, and all my accessories. What is the major difference in heads?
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 10:55 PM. |
