| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee |
05-17-2007, 08:46 PM
| | Stranger | | | Join Date: Apr 2003 Location: Washington state USA
| | engine swap Just a quick question, can I swap an engine out of a 91 yj (H.O.??)
into a 89 cherokee? I know I can use the block but can I use the
H.O. intake?
Thanks.
GEE I guess nobody feels like answering a noob here.
I guess we're not worth it.
No wonder this board is dying.
05-21-2007, 08:58 AM
|  | Carpal \'Tunnel | | | Join Date: Mar 2003 Location: Holland
| | Besides working my ass of I still find time to answer politely to your question. It has nothing to do with being a noob or not. I won't even ask if you allready used the search button.
You NEED to use the HO intake manifold because it's a different head than the lowport. Just swap the sensors and you'll be fine. You can leave away the EGR crap if your state emission laws allow you to. Swapping a High Output for a Non-High Output Engine - Jeep at Off-Road.com
__________________
HJ
If in doubt, add a bit more
Cherokee Pioneer '88 i6 2-door 5 speed mostly stock
05-21-2007, 01:08 PM
|  | Pooh-Bah | | | Join Date: Oct 1999 Location: Forest Grove Oregon USA
| | The board needs more people spouting off and disrespecting others to continue it's decline. Look around theres people with a lot more posts than you getting no response. A simple BTT usually helps get your post attention. I for one have never made the swap and don't want to hand off bad information. At one time there was quite an exchange of ideas here but petty B.S. has seemed to dry it up. Try to not help it along......
__________________ Rubbin's good wheelin'
________________________________________________
2002 WJ-IRO 3" Complete, Addco rear sway, Doestch Tech 8000's w/ bumpstops, JKS Discos,Cooper Discoverer STT'S 245/75/16 on 16X7 Black Daytonas w/ 4" BS. IPF Dual function lights, Unity 245k Spotlight. AM radio STANDARD!
| | Appologies I do sincerely apologize for getting testy there nix.
Thank you for the info, it is GREATLY appreciated.
It is my daily driver and the motor in it is dying faster
than I am prepared for. I DO need to use the egr BS.
Lovely western washington.
TY again
S.O. |
05-21-2007, 01:31 PM
| | I apologize for using harsh wording, it's just sad to see the boards decline. I'm hoping with everyone making positive contributions it will once again be a fast moving board. It's sad when I see my replies are the last ones made on numerous posts.
2002 WJ-IRO 3" Complete, Addco rear sway, Doestch Tech 8000's w/ bumpstops, JKS Discos,Cooper Discoverer STT'S 245/75/16 on 16X7 Black Daytonas w/ 4" BS. IPF Dual function lights, Unity 245k Spotlight. AM radio STANDARD! |
05-21-2007, 01:57 PM
| | The newer style manifold is not set up for an EGR. So I'm afraid you need to look for a lowport engine. 1 Plus: they're pretty cheap if you can find one.
__________________
HJ
05-22-2007, 03:52 AM
| | HO vs Lowport From the article you sent me to Nix it doesn't sound like
TOO big of a PIA to use the HO intake, but it didn't say
anything about problems with the egr. That, I would consider a MAJOR omission! So you're saying I would be best off getting a lowport head and using my stock intake?  That takes a lot of fun out of it!
Thank you again |
05-22-2007, 05:12 AM
| | The HO engines were designed with a different camtiming tomreduce NOx. But you would need the motormanagementsystem from the HO also to keep the emission within the limits.
The HO sounds magic, but it only has a bit more power at higher RPM's. The old Lowport has a bit more torque at lower RPM's, so you're not about to let go a big improvement. Besides, most '87 - '89 XJ's get rusted out or their manual BA tranies get blown, so there should be plenty of opportunities to get a lowport engine that's still in decent shape. As everybody wants the HO, the lowport should be about half the price.
If you find one, replace the oilfilter's O-rings, put a one piece oilpangasket in it and replace the rearmainseal. Maybe you need to clean the valvecover to make it breathe properly, but that can also be done with the engine in place. Put a new bead of RTV on the head, let it dry for an hour, put on the cover, then screw in the bolts loosely. Next day tighten the bolts, and your new old lowportengine will be leakfree.
__________________
HJ
05-22-2007, 10:06 AM
|  | Old Hand | | | Join Date: Dec 2006 Location: S. CA
| | Ya know, he may not have an issue if he swaps out the electronics as well....a bit more work but you would get rid of the Renix and the EGR issue would go away.
Smog laws should not be an issue...even in CA, you can put a newer motor in an older car...as long as you keep all of the gear that was attached to the engine. In the case of my CJ, it is now a 93 Chevy PU as far as the smog station is concerned.
__________________
AKA DDawg16
84 CJ7, SOA, 5.7LTBI, 4L60E, 32"x11.5, 4.10 gears, F/Det, R/ARB
89 Cherokee, 4.5" Lift, R/D44, 31"x11.5
Both Never Finished
05-30-2007, 08:59 PM
| | HO engine swap Hey Nix, from what you've said I CAN use the block and just go with a pre-HO
head and intake?? I have a line on another head and such IF that's how I can go. (the block is rebuilt already)
I know I'm a PIA but,,,,,,,,,
I truly apreciate your expert help.
AND everyone else's too!
Steve | | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! | All times are GMT -5. The time now is 12:52 AM. |
