| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee |
05-14-2007, 09:44 PM
| | Aprentice | | | Join Date: Sep 2002 Location: AZ, near Tucson
| | 3500 rpms max I'm working on my '90 Cherokee 4.0L, 4wd, auto. Mostly, it runs very well, but sometimes when I floorboard the accelerator and keep it down, it craps out around 3500 rpm, not fast enough to shift out of first. Sometimes it runs normally. It has new plugs, wires, cap, and rotor, and new fuel and air filters. I changed the fuel filter after the first time this happened. The other stuff was new before. I installed a new Borla header and a straight-through (cherry bomb) muffler. At that time, I checked the cat and could see through it, through a honeycomb matrix. It seemed to be quite clear. I'm thinking maybe fuel pump, but???
Any ideas? I'm pulling a travel trailer to Idaho in July, and it needs to be 100%. |
05-14-2007, 11:18 PM
|  | Pooh-Bah | | | Join Date: Oct 1999 Location: Forest Grove Oregon USA
| | It sound like your in the right neighborhood thinking it's the fuel pump, it could be failing under load and causing your problem. Your cat wouldn't have any effect such as you describe. The most common sign they are going bad is when they rattle or look melted or plugged inside. I would have the fuel pressure checked. IIRC there is also a tank filter which could be plugged but they are integrated with the pump assembly. Have you also checked to make sure you have no water in your gas? Does it backfire or sputter? Water could cause issues also.
__________________ Rubbin's good wheelin'
________________________________________________
2002 WJ-IRO 3" Complete, Addco rear sway, Doestch Tech 8000's w/ bumpstops, JKS Discos,Cooper Discoverer STT'S 245/75/16 on 16X7 Black Daytonas w/ 4" BS. IPF Dual function lights, Unity 245k Spotlight. AM radio STANDARD! |
05-15-2007, 10:27 AM
| | more on 3500 rpms max The intermittent problems are always the hardest...
The fuel strainer in the tank is new. I changed it when I had to replace the short hose inside the tank.
I cut the old fuel filter apart when I replaced it, and saw no sigh of water or rust.
No backfiring or poor running at all. Even when it won't exceed 3500 rpm it's still running smooth...
I might put a fuel pressure gauge on it and drive it around some. Or, I might just change the fuel pump and see what happens.
I hate changing parts to test. I call it the Christmas Tree method of troubleshooting, after how we used to change bulbs in a series-wired string of Christmas lights until we found the bad one.
I was hoping someone had seen this problem before and would reply. |
06-03-2007, 11:43 PM
| | Stranger | | | Join Date: Apr 2007 Location: Dunellon Florida
| | tps ? has the check engine light came on?
is it injected?
sounds like the tps is starting the go bad.
my 95 zj was doing simmaler then started stalling at low speeds . When I replaced the tps it was 4.slow no mow
get a scan or flash it yourself
__________________
DOIN WHAT IT TAKES & THEN SOME
| | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! | All times are GMT -5. The time now is 12:06 AM. |
