ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeep-Mid-Sized
Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee
Old 12-12-2005, 11:45 AM
Bama
Default transfer case problems
My transfer case slips out of 4l and 2h into 4pt.
Does any one know if there is a detent inside the transfer case? Mine is the one that has 2h,4part time,4h,neutral and 4l in that order and it is in a 94 Cherokee w/4.0 auto.
thanks any help would be great
Bama
Old 12-12-2005, 06:18 PM
krabysniper's Avatar
krabysniper is an unknown quantity at this point
Default Re: transfer case problems
I am not really understanding what your saying because there is really no way I know of that the transfer case could "slip" out of 4 low and skip by neutral and 4 hi full time (seems to me you have the select trac although I thought that they were 2h, 4h full time, 4 h part time, neutral, 4 low in that order) and even so it wouldnt be able to skip thru neutral from 4 low.
Old 12-13-2005, 08:31 AM
commandtoad's Avatar
Pooh-Bah
commandtoad is an unknown quantity at this point
there is a detent, but it's unlikely that's what it is.
sounds like the pads are worn or broken on the shift forks. check the rear output snap ring, they tend to break. i'm betting it's low on oil as well.
Old 12-15-2005, 02:11 PM
Bama
It slips out of 2h into 4 part time or it will jump out of 4l. It is hard to shift
Thanks Bama
  #5
Old 12-15-2005, 02:12 PM
Bama
Thanks I will check that
Bama
  #6
Old 12-17-2005, 07:35 PM
Aprentice
heavyequipment is an unknown quantity at this point
When the clutch gears in a transmission or transfer case get worn, they pop out of engagement under load. If the nylon pads on the shift forks get worn, the gears don't engage all the way, and pop out. After they pop out a few times, the clutch gears get worn more. Also, sometimes they pop out with so much force that the shift fork gets bent or broken. All these things should be checked if you open the case. The clutch gear teeth (or splines, really) are contoured so when they are fully engaged, they tend to stay engaged, especially under load.
Good luck with this - sounds like $$
Don't force it; get a bigger hammer
Off-Road Videos -
ATV Reviews -
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
