ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeep-Mid-Sized
Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee
Old 11-14-2005, 07:17 PM
BigNorm's Avatar
BigNorm is an unknown quantity at this point
Default Fuel gauge sending units
Does anyone know if the sending units are the same size in all gas tanks they used in the Cherokees? The reason I ask is I'm researching into building a 3.4L with the new style aluminum heads and the FI that goes with it. 2000+ heads and injection. I figure that the sending unit for the 4.0L with the fuel pump may produce enough pressure for the system I propose to use. If the sending units are the same size (doubtfull, but I can hope) then I can just replace sending units rather than have to buy an entire new gas tank. Thanx for any help you can offer. NORM
Old 11-14-2005, 08:38 PM
xjy173's Avatar
Carpal \'Tunnel
xjy173 is an unknown quantity at this point
Default Re: Fuel gauge sending units
I recall that when I was considering a 3.4 swap into my old 86 XJ, there was an aftermarket electric fuel pump that mounted in the engine compartment that supplied the right fuel pressure for the TBI 3.4L. There might be one out there that would work for what you're thinking about. Good Luck! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Old 11-15-2005, 10:59 AM
BigNorm's Avatar
I was thinking of using the in tank pump for the TPI. I want that sending unit because I'd think it would have a return line. I'm wanting to use a 3.4 out of a 93-95 F body and the heads on up from a 2000+ 3.4. These heads are aluminum and are supposed to have supperior flow characteristics and have larger valves as well. Thanx for the help though.
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
