dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee |
11-10-2005, 04:15 PM
|  | Keyboard Implanted | | Join Date: Mar 2003 Location: Holland
| | A nice drive with the XJ
It's with Dutch comments, but I don't think I need to translate... clicky |
11-10-2005, 05:20 PM
| | | Re: A nice drive with the XJ
I'm slow... The first frame the xj is fine. Then I see it being winched down into the hole. Then it looks like it is being winched across the pond. Am I right? If that's the case, why?
I see the front bumper is detached. I've seen that happen to an XJ first hand with the same or similar setup. Beefy bumpers are nice but careful consideration needs to be given to the mounts. They tend to rip out of the sheet metal.
11-10-2005, 05:56 PM
|  | I Might Just Know What I'm Talking About | | Join Date: Apr 2002 Location: Texas
Yeah, I'm confused as well. Translation please??
Edit: translated:
1.On a beautiful day you will drive a bit with your 4x4
2.Unfortunately come be stuck you on very smal richeltje
3.Nothing to the hand, using a quadrant is you rapidly downstairs.
4.Unless you send found oneself and for the second time are stuck, but now transverse on the richel
5.Yes, also on the other hand it is very steep
6.Even trying or that ice strong enough is there across drive.
7.Not therefore
8.Even with three quadrants succeeds it no longer to end up there reverse.
9.But then but liertje to the front and draw
10.This can be not well for your square wipers
11.Look nou, the monster of Loch Ness
12.Through the slow tempo must be passed there to in the late uurtjes
13.And then the bullbar tear on five meters for the side. Expired with quadrants.
14.At dagaanbreken appears that it has considerably frozen
15.Also of near it does not see good
16.There the rescuer in need is
17.Once on the dry land damage can be taken
18.The interieur in cold ijstinten
19.Pay attention especially to the enormous quantity mount space
20.Only one couple deukjes on this side
21.And as from this side it is exactly or he this way from the showroom comes
22.Only one beetje jammer of those lakschade to the front
ok, that didn't help at all...... |
11-10-2005, 07:04 PM
| | Journeyman | | Join Date: Jul 2004 Location: Cookstown, Ontario, Canada
Those guys are just retards.............not sure what they were trying to prove......except how to destroy an XJ.
11-11-2005, 12:45 AM
|  | Aprentice | | Join Date: May 2005 Location: Central Coast - CA.
So Nix. Did the XJ live?
11-11-2005, 02:24 AM
|  | Keyboard Implanted | | Join Date: Dec 2001 Location: Dayton, NV
I keep tellin' folks if they want to go submarinin' then buy a submarine! Now they've got the stupid chit on TV trying to sell the new jeep. I wonder how many idiots will forget to read the disclaimer at the bottom before they just drive their new vehicle into the ocean.
11-11-2005, 06:25 AM
Here's the translation:
1.On a beautiful day you go for a little ride with your 4x4.
2.Unfortunately, you get stuck on a very smal edge.
3.No worries, using a winch will help you rapidly downstairs.
4.Unless you steer the wrong way and get stuck for the second time, but now transverse on the edge.
5.Yes, also the other side is quite steep.
6.Let's try if the ice is strong enough to drive across.
7.Guess not.
8.Even three winches can't get it out backwards .
9.Let's try a little winch uo front and start pulling.
10.This can't be good for the wipers.
11.Look at that, the monster of Loch Ness.
12.Because of the slow progress, work lasts till the late hours.
13.And then the bullbar is ripped off, five meters before the side is reached. Done with the winching.
14.At dawn it appears that it has considerably frozen.
15.Also close it doesn't look good.
16.There's our saviour.
17.Once on the dry land damage can be inspected.
18.The interieur in cold ice tints.
19.Pay attention especially to the enormous quantity of lugage space.
20.Only a couple of dents on this side.
21.And from this side it looks exactly like it comes right out of the showroom.
22.Too bad for the paintdamage at the front.
11-11-2005, 03:41 PM
Notice that most of the hardware appears to be BOB....(Bolt On Bling)....
And I promised myself I would be politically correct and not make any reference to the fact that the drivers apear to be Asian....(might explain the wrong turn)
11-12-2005, 02:57 PM
Rolly Cow! Jeep no drive under ice! I no believe jeep comercial no more!
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 11:37 AM. |
