Interior lights stuck on, is there a relay ? - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeep-Mid-Sized
Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee
Old 08-05-2005, 08:44 AM
Journeyman
mjl91xj95xj is an unknown quantity at this point
Default Interior lights stuck on, is there a relay ?
Got home from work last night, noticed my interior lights were stuck on. Its not the dimmer on the headlamp knob. And I pulled all of the door and tailgate switches and disconnected to break the circuit. [img]/ubbthreads/images/graemlins/AR15firing.gif[/img] Still on.
My wiring diagram in my haynes manual doesn't show a relay, but it seems like one may be kicked and fried. The reason I say that is that they came on when I opened the door, but apparently never went off. Unless my headlight switch cooked, but it doesn't seem like that. The headlamps work fine and the switch is only a year old. I will chase wires when I get home tonight, but pulling the fuse to kick the lights off is a pain in the rain and my radio doesn't work with it pulled. I hope its just a relay and not a short somewhere.
Any ideas??
Thanks, Mike
Old 08-05-2005, 09:33 AM
stump_breaker's Avatar
stump_breaker is an unknown quantity at this point
Default Re: Interior lights stuck on, is there a relay ?
Does your XJ have the rear light (at the hatch) that you can press when the hatch is open to give you a "cargo" type light? If so, you might see if it's on.
Old 08-05-2005, 11:31 AM
Journeyman
Nope. I have a rear cargo light, but not a seperate switch. I've seen the type of setup that you are referring to, sort of like a map light for the cargo area.
My dome, courtesy and cargo lamps all stay on. I may end up pulling the headlight switch/ dimmer out to trace the wires. I'm convinced there is a relay, but I have no clue where.
Old 08-05-2005, 01:53 PM
tincan is an unknown quantity at this point
Before you pull the dash stuff,,,at the rear cargo light disconect the wires and see if that solves the problem...then if it does---- I found a mercury switch in my gate,,yours may be broken or or or or....g/luck
  #5
Old 08-05-2005, 01:59 PM
Journeyman
I'm not quite sure what you mean by mercury switch. I have disconnected the wire at the tailgate latch that, I believe, causes the lights to come on when the gate is open.
Thanks
  #6
Old 08-06-2005, 02:07 AM
krabysniper's Avatar
krabysniper is an unknown quantity at this point
Mercury switch he refers to is like the little glass bubble with wires at both ends and the liquid silver stuff (mercury)inside, that you find in your average home thermostat controls. It's inside the hatch and is what completes the circuit when you open the hatch thus turning on the lights.
  #7
Old 08-08-2005, 07:22 PM
Pooh-Bah
GP'n is an unknown quantity at this point
[ QUOTE ]
This sounds like the problem child right here. The door you opened and the light that never went off.
The dome works off a switched ground. You may have to pull the wire OFF the switch to check it for shorting to ground. This will make your light work all the time. Any place the dome wire (bare) touches the body is a potential close for the circuit, or any switch that does not open will do the same thing.
  #8
Old 08-09-2005, 01:25 PM
Journeyman
I did disconnect that switch from the connector, but I didn't pull it out to see if the wire was rubbed through.
Another point for diagnosing the problem, just the lights are on, the key buzzer/door ajar buzzer still works correctly, and responds to the door switch.
I'm still pulling the fuse for now, I haven't had the time to trace anything yet.
This is kindof like when my TA got stolen. I drove around using a screwdriver to start it for 3 months until I had the time to switch out my steering column.
  #9
Old 08-10-2005, 12:46 PM
NIX's Avatar
NIX NIX is offline
NIX is an unknown quantity at this point
The drivers' door switch is a double one. 1 ground for the buzzer, 1 for the lights. Any ground wire that touches the ground because of a short, caused by a broken switch or wire or so can leave these lights on. It doesnt matter whih one, because it's a kind of ground harness that makes the lights go on. So you have to find out if any switch is broken or a wire slipped off a contact. I'm not aware of any relay. The interior light in mine is a direct sytem. Have fun finding out and let us know when you solved it...
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
