dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee |
09-06-2004, 02:41 AM
|  | Old Hand | | Join Date: Aug 2002 Location: Hawaii
| | np231 with tail-shaft out of yj
My bud has one he wants to get rid of. Will this work in my XJ? Is it any different from the NP231 I have? I figured if it will work, it already has the tailshaft conversion and its out the jeep. I can install a 4:1 ration and heavy duty chain. Oh yea, GOOD to be back guys...i missed you all!!!!!!!!!!!!!! [img]images/graemlins/RockOn.gif[/img]
09-06-2004, 08:56 AM
|  | Enthusiast | | Join Date: Nov 2001 Location: Burkburnett, TX
| | Re: np231 with tail-shaft out of yj
As long as the input spline count is the same as yours. It'll either be 21 or 23. Outside of that they are the same unit. The difference in the spline count is in the years they were made. My 88 had 21 and my 90 had 23 splines. The change was made sowhere in there.
09-06-2004, 12:28 PM
|  | Enthusiast | | Join Date: Oct 2003 Location: Grass Valley, CA
As long as it the same spline count (as noted above) then yes it will work. I swapped in a YJ NP231 earlier this year and the only things you need to address are:
1) Front DS output yoke. They are different, so just use the one off your old case... works perfectly.
2) The linkage "tab" that attaches to the case is also different, again, use the one off your old case and everything should go together like a dream.
Good luck!
-jm
09-06-2004, 02:11 PM
ok so the tail shaft conversion with the sye is good to go too then right? I figured the case itself was good to go but i need to know if the sye is the one i need
09-07-2004, 01:25 AM
I would imagine that the YJ guys buy the same SYE as we do... And since we have determined that the cases are essentially identical -- it should theoretically work. I cant imagine why it wouldnt.
My YJ NP231 came with a SYE, but swapped back to a stock output shafts because I aint ready to run the SYE yet. SOOOOOOO... let us know if for some reason this doesnt work. But again, I really think everything should go together perfect. | | Thread Tools | | | | Display Modes | Linear Mode |
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 02:03 PM. |
