dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee |
08-21-2004, 06:24 PM
| | | My jeep is shutting off during right hand turns
99 cherokee, 4.0 dies, when we take a hard right hand turn at any speed over 25 to 30 mph.
Can anybody help?
Talk to several shops and the local dealer, none have a psotive answer for the problem
08-22-2004, 12:30 AM
|  | Addict | | Join Date: Jan 2004 Location: Temecula, CA
| | Re: My jeep is shutting off during right hand turns
Look for a loose wire. That's about the only thing I can think of that would produce those symptoms.
08-22-2004, 12:52 AM
|  | Addict | | Join Date: May 2003 Location: Albany, Oregon
Are you below 1/4 tank of gas when this happens? Johnswane(sp) had a similar problem and said that it ended up being the fuel pump. I have the same thing happen to me on my 98 during lefts. I have been too lazy to drop the tank and change it (and the lack of funds), to see if it fixes the problem. Apparently it worked for John though.
08-22-2004, 10:27 AM
doesn't matter about fuel level, it has does it low or full.
Last night it did it driving stright and level going over some filled pot holes.
Still looking for any loose wires.
08-23-2004, 10:48 AM
|  | Old Hand | | Join Date: Nov 2002 Location: Pleasant Grove, Utah
Maybe even fuel pressure regulator or fuel pump, we changed them out on my dad's last night. His was dying going uphills. Just a thought- you can have a pressure test done under the hood. They hook up a gauge to the fuel rail.
08-23-2004, 02:20 PM
I have a friend that this was happening to in his wrangler. Would make a left hand turn and the engine would die. Straten the steering wheel and it would fire back up. Turned out to be the steering colum pinching one of the ignition wires when turning left. This was caused by him pulling himself in by grabbing the steering wheel.
08-23-2004, 04:12 PM
97s and up have the capsule in the tank. It's a sender+p/u+ screen+ filter+ pump+ regulator all in one deal....
09-06-2004, 02:34 AM
|  | Old Hand | | Join Date: Aug 2002 Location: Hawaii
the same thing was happening to mine when i first bought it. It was the fuel pump...mine was warrenty work so i didnt have to drop the tank and fix it, yes its inside the tank. the bill was somewhere around 700 bucks.
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 08:19 AM. |
