| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee |
07-29-2004, 07:39 AM
| | | Re: Need a little help it is black right now it is a small area about 1/8 x1/8 big not really noticeable but i want to cover it up... and yeah my rims are 15s...
here is the link again.. its a Tough Country Jeep 1987-01 Cherokee 4wd 3.5" EZ-Flex performance suspension lift kit.. http://www.suspensionconnection.com/...on/438013.html |
07-29-2004, 10:38 AM
|  | Addict | | | Join Date: Jun 2003 Location: Wisconsin
| | Re: Need a little help If I were spending that much money, I'd be looking at the RE or Rusty's kits. Some on the board don't care for Rusty's, but I haven't had any issues and two other guys I wheel with are happy with their kits. I see two things in your lift selection that don't seem to get good backing from board members. The first being blocks in the rear and the second being tracbar relocation bracket instead of a complete new adjustable one. Take a look at this page for options in that 3.5" lift height: http://www.rubiconexpress.com/dynami...p?folderid=185
or this one: http://rustysoffroad.com/Merchant2/m...ode=sus_xj_kit
If the links don't work, just copy and paste the address. Keep in mind though you would still need shocks with the RE kit. |
07-29-2004, 10:53 AM
|  | Keyboard Implanted | | | Join Date: Nov 2001 Location: N.Dakota, United States of America
| | Re: Need a little help Actually relocating the axle end of the trac bar I don't have a problem with, using an extended frame side mount I feel is a major no-no, but yes I agree an adjustable trac bar is the best way to go. You just gotta be sure of the max lift your gonna wanna go or you'll be buying a different one later if you wanna go over 3". |
07-29-2004, 11:11 AM
| | | Re: Need a little help the thing that sucks here is Massachusetts is legaly i can only alter my ride height by 2 inches... which realy sucks.. so im afraid that if i go with a 4.5 inch lift that i wont be able to get a sticker...
also while looking through the Rubicon Express lift kits i found this one RE6030 3.5" XJ Super-Flex Kit its on the bottom of the page.. does this kit have everything that i need to lift my jeep? or do i need to buy aditional parts? |
07-29-2004, 03:53 PM
| | | Re: Need a little help ok, the real difference between the kits is the quality. certain kits sag over time worse than others, RE has the best for the buck kit out their. the difference between the ride and flex kits is the controls arm ends, the ride has a rubber bushing for a really nice ride the flex has a joint for really good flex. my ride arms had more than adequate flex and I saw no reason for the flex price. shocks are the only thing the RE kit will not come with. also the trac bar is not complicated or costly all you have to do with a 3.5" lift is unconnect rock the jeep till its centered on the springs, then redrill the stock bracket to mount the stock trac bar, I had to remount mine about 1/16th. cost of moving trac bar nothing. a better opton is to check jeepsunlimited and buy a used RE 3.5" kit off someone moving up in hieght, or if 2" is all you can do used a budget boost and run 30-31's. wonder if you could run 4 spare savers at inspection to reduce your hieght. |
07-29-2004, 08:19 PM
| | | Re: Need a little help i have been reading post and people are saying that they get drive line vibes? what is that and how would i take care of that?
I am thinking about getting the RE 3.5 Super flex kit.. so all i need is Shocks right? which ones would you guys suggest? |
07-30-2004, 02:53 AM
|  | Carpal \'Tunnel | | | Join Date: Mar 2003 Location: Holland
| | Re: Need a little help A 2000 might suffer som driveline vibrations at 3.5 lift. Maybe a TC drop and some axle shims will cure that, otherwise an SYE is nessecary.
Vibrations are caused because of the sharp angles due to the lift. They can be cure by making them less sharp or by replacing the driveline with parts that tolerate sharp angles. An SYE (Slip Yoke Eliminator at the TC) requires a new DS (drive shaft) with slip yoke in the shaft and a double joint at one end. You also need to make your pinion point up, 1 degree less than the DS. It can be doen with shims or rewelding the spring perches.
Here's some info . SYE . Vibrations . More driveline info . More links . |
07-30-2004, 09:22 AM
| | | Re: Need a little help would this kit work on my 2000 Cherokee Sport? http://jeepinoutfitters.com/products.asp?ID=186
also how hard would it be to put on? and if that one wont work do you know where i can purchase a whole kit? |
07-30-2004, 03:51 PM
| | Carpal \'Tunnel | | | Join Date: Aug 2002 Location: vacaville, ca
| | Re: Need a little help yep and i know where you can get it shipped to your door for 180$ , pm me if you want the link |
07-30-2004, 05:59 PM
|  | Veteran | | | Join Date: Apr 2002 Location: Texas
| | Re: Need a little help I actually caught myself after I posted but this dang board wouldn't let me log on to correct myself [img]images/graemlins/cussing.gif[/img]
First time I have been able to get on in two nights! | | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Need Gas Mileage & Power?- Free flowing performance exhaust can
Exhaust has for your gas or diesel truck. | Off-Road Videos - Check out over ten years of extreme 4x4
action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the
dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki,
Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and
model. Read expert opinions and follow custom project vehicles. | All times are GMT -5. The time now is 10:02 PM. |
