ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeep-Mid-Sized
Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee
Old 07-09-2003, 04:21 PM
Default All Wheel Drive Conversion?
I have a 1995 Grand Cherokee that is all wheel drive. I am considering converting it to a select track system. Does anyone know if it is worthwhile and what would be involved?
Old 07-09-2003, 04:58 PM
ipkyss
Default Re: All Wheel Drive Convertion?
lots of work, and why would you want to just out of curiosity.
Old 07-09-2003, 05:11 PM
Thanks for the reply. I've just heard that the "Select-Trak" is the better system in the Grand Cherokee and thought it would be nice to be able to leave the vehicle in 2 wheel drive? Also, I was not sure if I could tow an all-wheel drive Jeep behind my motorhome?
Old 07-10-2003, 01:01 AM
tuckjaminout
If I were going to tow my Grand Cherokee, I'd have a reciever welded on the front,under the bumper. that way, I could put a hitchmount on the front of the bumper and tow it wherever I wanted to go. Just put the Transfer case selector switch in neutral and the trannie in neutral. It should pull easily this way, just fine.....
  #5
Old 07-10-2003, 02:08 PM
Journeyman
xjFozzy is an unknown quantity at this point
All-Wheel Drive vechicals CAN NOT be towed, without removing the drive shafts. Mainly becuase there is no way to take the transfer case out of gear. At least thats the way every AWD I have ever seen works.
  #6
Old 07-11-2003, 09:36 AM
Sycho15's Avatar
Sycho15 is an unknown quantity at this point
To do the conversion you'll need an NV-242 transfer-case, a shifter for it (though I think yours would work), and possibly new driveshafts.
I have an NV-242 for sale for $200 if you're interested. I've swapped some x-cases before and it's not really all that difficult. 8-bolts disconects the driveshafts, 6-bolts disconects the x-case. Disconnect the shifter, the vent hose and the speedo-cable and yank the 'case (some may have other wires and vacuum hoses). Installation of the new 'case is just the reverse of that process.
  #7
Old 07-11-2003, 06:42 PM
et89xj is an unknown quantity at this point
I would use a 242 or 231(I like the 231s better myself)...One of the main reason to swap out the AWD is b/c the like to blow up with just a few psi diffrences in the tires...That and you get ride of the center viscus diff [img]images/graemlins/chair.gif[/img]...andy
Off-Road Videos -
ATV Reviews -
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
