ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeep-Mid-Sized
Jeep-Mid-Sized All discussion of mid-sized Jeeps: Cherokee, Grand Cherokee
  #11
Old 01-01-2002, 11:52 PM
athlonaj is an unknown quantity at this point
Default Re: V8 swap using AMC V8?
Hey the more I'm thinking of it the more I want to do it. I'm looking to get any huge horsepower gains just simplifying things for the long run. And I'll take you up on that offer too.
  #12
Old 01-02-2002, 12:11 AM
Looking more into the AW4 transmission here's what I've found so far. A person could technically disconnect the TCU from the trans but you would have to add a few manual switches such as one to engage the torque convertor. Might be fine for me, but my wife drives it on the rare instances where I need to work on her car.
So far I've found the transmission's computer gets an input signal from the TPS and also one for vehicle speed. The TPS I can work around that, where would it get the vehicle speed input from since the speedometer is cable operated? Is there a sensor in the backhalf of the trans that measures the final output rotation?
  #13
Old 01-02-2002, 04:39 AM
Sycho15's Avatar
Sycho15 is an unknown quantity at this point
All AMC 6 and 8 cylinder engines share the same bellhousing bolt pattern. The straight-six that won't bolt up would be the Kaiser-era 230 "Tornado", but then the Buick 350 was the V-8 of that day...
You may find it surprising to know that a 304 is much harder to find than a 360. The Grand Wagoneer used the 360 exclusively for a very long time (and ended production in '91, so you can still get an AMC V-8 thats newer than your non-HO 4.0s). The 360 was also found in many other Full-size Jeeps like the Pick-up, Cherokee, and Wagoneer.
All AMC V-8s share the same block, only the bore and strokes are different. This means that if you install a 304 and get tired of it, a 401 will drop right in and all the accesories will bolt on. Many internal parts are interchangeable as well, camshafts, crankshafts, bearings, etc. 304 and 360s have the same crankshaft, but a 401 crankshaft in a 360 strokes it out to 385, and a .03 overbore creates a 390.... BTW, the 401 was last used in '78, and came with a forged steel crank and rods from the factory!
As for the motor-mounts.... The driver's side mount is fine, but the passenger-side mount has to be notched. A 4" angle-grinder with a cut-off wheel can do the job just fine. (This is for the CJ/YJs, I'm not sure how different the motor mounts are on the XJ/MJ/ZJs, but it shouldn't be a difficult mod to mount this engine.)
They use the Duraspark electronic ignition system, which is really quite powerful and very reliable (and simple to install, check out my webpage "Ignition Woes".) Stick some Ford parts on it like the TFI coil and a cap & rotor from a '90s V-8, and it becomes very powerful.
They have great carberators (MC2100) and there are EFI kits available from MOPAR, Howell, Holley, and Custom EFIs.
I wouldn't try using the AW-4 behind it because of the electronics invovled, but the TF-999 (used in CJs) and TF-727 (used in full-size Jeeps) are reliable, durable, and best of all- plentiful. Your NP-231 or 242 x-case will bolt right up, as will the NP-208 found in the full-size '80s Jeep Trucks. The NP-208 has a 2.61:1 low range, fixed rear yoke, and 32-spline output shaft! It should be the same size as an NP-228 (which I hear is just the full-time variant of 208).
Since we've just discussed using the engine, transmission, and transfer-case from an '80s FSJ, why stop there? The front and rear D44s under them are almost the same width as mid-size Jeeps (2" wider I think). Front axles newer than '85 don't have any vacuum crap on them (due to the change from the NP-229 to 228 x-case). They have the common 6x5.5" lug pattern, so finding cheap (or even cheaper, used) rims is easy. The drive flanges can be removed and manual-locking hubs bolted on.
But then, I'm a bit biased. I think a Full-size Jeep drivetain should be in any Jeep that sees more use than daily driving.
I know what your thinking- how could all this be cheaper than rebuilding/stroking the 4.0? Well, how often do you find '80s Grand Wagoneers with rusted out bodies for sale for less than $1500? Or find them in the junkyards? Maybe you'll find the set-up piece by piece like I did... Keep reading.
I'm doing this swap to my Wrangler. The NP-208 cost me $150 (and I sold my 21-spline NP-231 for $100). The TF-727 cost me $450 $50 shipping from someone on ORC. He just had a $600 HD rebuild done to it and decided not to use it and parted out the Jeep instead. The 360 I haven't bought yet, but there are two that run very nicely at a local junkyard and they want $400 a piece for them, all accessories included. The D44s were $150 each at another junkyard, and had 3.31 gears in them (better than the 3.07s in my stock axles). Granted, I spent a lot of money getting new 4.10 gears, carriers, installation kits, and EZ-Lockers for them.
'89 Comanche, '89 Wrangler, '74 Postal
  #14
Old 01-02-2002, 10:08 AM
Oh man do I feel like a real idiot now. There was a FS Wagoneer (87 I think) sitting for about a year in this guys driveway. It ran and drove but needed a new headgasket on one side and exhaust work, was a rust bucket. Could have snagged it for $500. GRRRRRRRRR.....it's gone now. I'm keeping my eyes out for another, I like the idea of swapping everything, axles and all is fine with me. Might as well do it right the first time.
  #15
Old 01-02-2002, 10:14 AM
Carpal \'Tunnel
Chris_MJ is an unknown quantity at this point
I know what you mean. I could have gotten an XJ Wagoneer with 44 rear for $650. And I would have had a whole bunch of extra parts, too. It's gone this morning.
Just because I don't care doesn't mean I don't understand!
'88 MJ SporTruck shortbed
Rebuilt 2.5L: 40 over rings, 10 on crank, 10 on bearings
nearing 400K
  #16
Old 01-02-2002, 11:03 AM
Sycho15's Avatar
You have to come to the point though, when you decide whether or not it is worth the effort to take everything from the FSJ and swap it into a MSJ, or just wheel the hell out of the FSJ instead! They are no slouch off-road either.
Thats why my Comanche may be replaced by a full-size J-truck someday.
  #17
Old 01-02-2002, 11:07 AM
Yeah I've thought of that, it would be more practical just to wheel the one but.... part of the reason of doing it is to put together something unique that not many people will have. Plus if I did everything based on practicality I would probably be driving a mid-80's station wagon with woodpanelling down the side. You know how it is, half the fun is just seeing if you can actually do it.
  #18
Old 04-07-2009, 04:58 PM
Stranger
jeepxj87 is on a distinguished road
Default
i am going to do the same swap a amc 304 v8 into my 87 xj if you have any advice for me that would be great!
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
