ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeep-Full Sized
Jeep-Full Sized All discussion of full sized Jeeps: Wagoneer, Full Size Truck
  #11
Old 05-03-2001, 03:36 PM
Default Re: Need info on swapping spring over axles
THANKS, AS IM SURE U KNOW IT LOVE, SWEAT AND BEERS TO BUILD ONE. THAT AND SOME ONE SAYING THAT IT CANT BE DONE !!
WHATS WRONG WITH YOUR FRONT SHAFT ??
89 2D XJ, 9+" OF LIFT, LOCKED F&R, 4.56, 4.1 LR, 38 X 12.5 TSLs AND TO MANY OTHERS TO LIST !!
I LIKE IT DIRTY,
XJ89XJ
  #12
Old 05-15-2001, 11:26 PM
Thanks for your help
  #13
Old 05-15-2001, 11:40 PM
What did you do for rear springs? Or was both your front & rear springs under your axles. With mine it is just the front that is under the front end.
  #14
Old 05-16-2001, 08:48 AM
As for the rear, I did a shackle inversion and fabbed my own mounts to compensate for the 7" gained up front with the SOA..here are some pics...
This is the front mount of the rear springs... drops front mount 5.25"
This is the rear shackle mount I made...
78 Wagoneer
14" total lift
4.89's/Lockers/39.5" Swampers
http://home.earthlink.net/~tjnkk
  #15
Old 05-16-2001, 08:54 AM
XJ89XJ,
I hear that!!! NOONE thought a Waggie could fit 39's without MAJOR trimming! If I didn't have all the brewskies over the 3 years I have invested in this, I may have been able to afford my front shaft!!! LMAO
the problem with the shaft is that the factory CV front shaft is limited to 16-22 max operating angle.... I 'SIT' at 32 degrees!!!! and I droop to 55 degrees!!! That is why I required a high-angle CV shaft to be built from one of 3 companies that can do it or say they can... all want an average of $800 for the shaft.... guess I just have to save the $$$$
78 Wagoneer
14" total lift
  #16
Old 05-16-2001, 11:33 PM
RB, keep me informed of the hi angle front shaft...im thinking along the same lines..what companies do u favor??
kenall
  #17
Old 05-17-2001, 09:29 AM
Ken,
No problem.... the three companies I am taking to are in preference order:
1. http://www.gloeco.com AA Arizona Driveline... they make the Bad Boy Junior... look under their custom high angle shaft section
2. http://www.highangledriveline.com His name is Jesse...had the article in the current 4x4 mag on his 80 degree 1 ton shaft...nice guy
3. http://www.4xshaft.com Tom Woods custom shafts
PS---- Mark (Above the Law) has been trying to get in touch with you about the QT parts.... email him at drew350@aol.com ---his email is down, use Drew's account for now and reference Mark in teh subject...
Get to IRC Ken..... haven't seen you there in a while.
Have a good one..
78 Wagoneer
14" total lift
  #18
Old 05-17-2001, 06:39 PM
Is there anyway you can drop your drivetrain a bit? I done it with my 72 GMC for my 6" lift to help with the driveline angles.
  #19
Old 05-18-2001, 12:32 AM
what is the dia of the ujoint at the xcase for these companies??
can it still clear an AT tranny pan??
  #20
Old 05-18-2001, 12:35 AM
RB...drew350 had 'permanent fatal errors'
Off-Road Videos -
ATV Reviews -
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
