Re: Welding?!? Welding to any frame can be tricky. What part of the frame are you welding to? The steel in the frame is made from a special spring type steel that allows it to flex, then return to the original position. If your welding to the but end rear you may be ok. Personally thats the only place I'd weld on my truck. It depends on what type of rod you want to use as to the machine you need to use. If you use a 1/8 " or smaller rod, the machine you mentioned should work. However dont plan on alot of non-stop welding.
Any welding on the side rails of the frame may cause serious damage to the steel, allowing it to crack or break under extreme conditions.
ASWSR
Alan Williams |
