ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeep-Full Sized
Jeep-Full Sized All discussion of full sized Jeeps: Wagoneer, Full Size Truck
Old 01-23-2006, 03:41 PM
carburetorcandy
Default high idle prob and alotta free play in steering
Ok it's me again .. told you all there maybe some future post's lol ... anyways need some help my 87 wagoneer (Straight 6)limited is givin me some minor problems first of all I have way too much free play (too much give) in my steering? and Second I'm idling between 1500-2500rpm when she heats up especially in neutral and park... If anybody has any advice please feel free to post. Any suggestions would be very greatly appreciated ! Sorry if I'm bein a bother just wanna get her running top notch !
Thanks, ~Candy
Old 01-24-2006, 10:27 PM
Journeyman
TNCowboyPRCA is an unknown quantity at this point
Default Re: high idle prob and alotta free play in steering
the free play can usually be solved with an alignment, if parts are worn out then youre lookin at new steering components. as for the idle, id need to know if its carberated or fuel injected. happy to help, you can also private message me.
Old 01-25-2006, 06:10 PM
85irocz-28's Avatar
Journeyman
85irocz-28 is an unknown quantity at this point
Find out what is loose in the steering. Have someone get in the cab and start it up. Keep it in park, don't move anywhere!
Have the person move the steering wheel left and right while you are inspecting all of the steering parts underneath. Stay clear of the moving parts (including engine belts and the fan.)
Look for play in tie rod ends, steering gear box, etc. Find out what you need to replace or tighten to stop the slop in your steering before having it aligned.
Like TNCowboyPRCA said, is it fuel injected or carb?
Old 01-26-2006, 04:39 PM
carburetorcandy
Yeah that would help wouldn't it LOL it's fuel injected ... Really appreciate the help fellas !
Thanks MUCH, CarbCandy lol !
  #5
Old 02-10-2006, 10:49 PM
danthe555man
i had to replace the track bar just last week (no grease fittin from factory)and i know that has really nothin to do about the freeplay in steering but it will make the other rod ends wearout fast from the vibration.OH and you just put a TBS in right??Did you find out if you adjust it's position for the right voltage output when you installed it?(4.2volts on connector D as negative,and B as positive with key in ON position and connectors still connected)....make sure the throttle cable is free to close all the way down.if that cant get it i have more info to try
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
