Need info for 1953 Willys Truck - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeep-Full Sized
Jeep-Full Sized All discussion of full sized Jeeps: Wagoneer, Full Size Truck
Old 03-13-2005, 07:26 PM
53WillysTruck
Default Need info for 1953 Willys Truck
I just recently purchased a 1953 Willys pickup from my grandfather for 500$. It has a 4cylinder and original trans and transfere case in it now. It is 4wd. With the truck also came the Jeep 304V8, heavier transmission and heavier transfere case. the V8 and tranny and transfere case are being put in definately. I was want to lift this truck and make it off road worthy. What size tires can I fit on this truck with no lift? Also what lifts are there out there for this truck? If none who would be the best person to get intouch with about some info on this truck. Also I want to bolt in a Chevy 350 small block. Will it bolt right up or do I need an adapter plate? Thanks.
Old 06-08-2005, 09:38 PM
Arlyn
Default Re: Need info for 1953 Willys Truck
If you're on a budget and do your own welding, just stuff the 304 and all in and hope for the best. BUT if you are spending any amount of $$ do it right, Go Ford!
We are finishing up a '60 Willys wagon retrofit. We are putting in a Ford 5.0 out of a '94 Mustang and a New Process 435 tranny and a NP transfer.
The next thing that you need to think about is the axles and brakes. The old axles won't stand up to much horse power and they are hard and EXPENSIVE to get parts for. The ratios are really low and you will hate it with a modern engine. The brakes on those old Jeeps really bite and are real hard to find parts for!
A front axle from an International Scout II '74 or later is a Dana 44 and will give you disc brakes up front. The old Willys trucks are extra wide in the rear, so get your rear axle from an International Travelall. It will probably be a Dana 60. These axles will probably have a ratio of 3.73, but MAKE SURE THEY ARE THE SAME!! Dana's are easy to get ring-and-pinions for. Your old wheels will bolt up (5 on 5 1/2) but won't seat correctly because of depth so toss them.
For anyone reading this who is doing a Willys Wagon, you can use the rear axle off of the Scout II.
Get the proportioning valve off of the Scout and use a Ford F100 circa 1970 master cylinder. Rebuild the disc brakes with Ford F150 calipers, circa about 1979. They are the same thing as a Scout set, but won't cost the extra bucks for the obscure reference. Get the brake and clutch pedals out of an old Ford van, around 1960, because they mount on the firewall. Reinforce the firewall.
You can mount the rear axle up pretty easily by moving the spring mounts on the axle tubes out. The front isn't quite that easy, but that leads you to some interesting options. You will have to move your spring mounts on the frame out 5/8" on each side, but that gives you a good excuse to do a shackle reversal, i.e. put the shackles in back where they give you the best on and off road response to big bumps.
Now you have to figure out the steering. A Saganaw box off of about a '72 Comaro or Firebird with 3 mounting ears has the right valve set for you, BUT get the pitman arm off of the Scout II, it's longer.
You will undoubtedly need new springs and Alcan springs are (in our shop's opinion) the best way to go for your money. You will probably need custom drive shafts now because of the increased horsepower and the new distances.
Now that you've done all that, you have to paint it nice so that people don't refer to it as an "Old POS." A really tricked out '50s Willys truck is a slick ride.
Do good work and keep in touch. Send pictures.
Old 06-10-2005, 02:52 AM
DudeBud's Avatar
DudeBud is an unknown quantity at this point
[ QUOTE ]
Go Ford !
[/ QUOTE ]I 2nd that
Old 07-22-2005, 05:34 PM
Wilbur
I have a 53 Willy's Delivery that I put onto a 1979 Cherokee WT frame. The wheel base is only 4" longer on the Cherokee then the Willys. If you have the FSJ frame, and are on a budget, you may want to consider that route. It involved moving the engine back 5" in the frame, 2 new drive shafts. Doing it this way, I was able to use everything (steering, wiring harness, brakes etc) from the FSJ. You need to weld new body mounts on the frame, make a new tranny cross member. I don't know how it would work with a pick-up, but I think my delivery turned out fantastic. Now I can just buy FSJ drivetrain parts.
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
