Re: Electrical Question!
Would be nice to more about what type Jeep, Age, Miles, etc. Fill out your bio and then anyone can fill in the details...
Now with the problem..no it is not normal. If the Jeep is older look for frayed wires, bad connections. Etc
Check all ground straps, battery to body, body to frame, engine to frame, engine to body.....
Pull the tail lamps apart and look for corroded sockets, same on the front....
Bet you find the problem is corroded contacts and bad grounds. [img]images/graemlins/burnout.gif[/img]
